E-blocks PC interface
Posted: Thu May 12, 2011 1:15 pm
by NerdHerd
Hi, im new to the e-blocks and was mondering if somebody could tell me how to connect the eb006 board to the PC and what must i do software wise to communicate between the flow code and labview?
Re: E-blocks PC interface
Posted: Fri May 13, 2011 2:11 pm
by NerdHerd
Anything you have to help will be appreciated maybe just the flow code side of things ..and is the USB cable only used for programming or can i use it to communicate with other software?
Posted: Fri May 13, 2011 2:35 pm
by Spanish_dude
To connect the PIC Multiprogrammer board to your PC you'll need a USB type A to B cable and plug it into your PC and multiprogrammer board.
Connect a DC 12V or 14V supply to GND and +14V.
I can't help you for labview.
Cheers,
Nicolas
Posted: Fri May 13, 2011 3:51 pm
The USB socket on the EB006 is only available for programming, ICD and the Scope operation.
To allow Labview/VB/Delphi to work using USB with the EB006 board you will need the following.
18F4455 chip or other USB compatible device
4MHz crystal or other USB compatible crystal
EB055 USB E-block
The EB055 datasheet should detail everything you need to know.
An ECIO is also a great choice for doing USB communications.
