Hi tech Compiler V9.81
Posted: Mon May 16, 2011 9:41 am
by barryw
Hi I'm trying to compile to a PIC16F1826 with a bit of code writen for a 16f 818, have installed the compiler but get the message
(902) no chip name specified; use "PICC--CHIPINFO" to see availble chip names.
What am I not doingcorrectly?
Re: Hi tech Compiler V9.81
Posted: Mon May 16, 2011 10:34 am
Have you changed both your compiler and linker options in the compiler options window?
Also have you changed both the location and parameters for both of the above items?
Details of what you need to do are available from here.
http://www.matrixmultimedia.com/mmforum ... =26&t=6812
If your still having problems then let me know and I will look into this for you.
Posted: Mon May 16, 2011 12:00 pm
by barryw
Well I found a typo in the compiler Parameters, have corrected it and now get
(908) Exit status = 1
when I try to compile. any ideas.
many thanks
Barry
Posted: Mon May 16, 2011 2:19 pm
Hi Barry,
Any chance you can attach your Flowcode program and the compiler output msg.txt file that is generated by Flowcode and I will have a look for you.
Posted: Mon May 16, 2011 3:54 pm
by barryw
Attached is the file i'm trying to compile, it seems as if it is ccp2 that is not reconised
barry
Posted: Mon May 16, 2011 5:06 pm
Hello Barry,
Unfortunately it looks like the 16F1826 does not have the CCP2xxx registers meaning that the default PWM component will not work with this device. I will have a bit of a look into this and see if we can make it work with another of the capture compare peripherals present on the device.
Posted: Tue May 17, 2011 7:44 am
Just a suggestion. (sorry if not that good). If having difficulty assigning a different capture compare peripheral. Could the 16F1827 be used instead, since that has 2 CCP registers you can use both PWM's directly, plus it has double memory (7K compared to 3.5k). For the dip version there is only 11p difference in price for a quantity of 1 - 9 in farnell (uk site).
Posted: Tue May 17, 2011 8:04 am
by barryw
Hi Guys, Well it seems as if the 16F1827 is the way to go with this, there will be a lot of redundant menory bu what the heck, Also when I tried to use the 16F1826 with 1 PWM it would not compile as it did not recconise, the ccp2 commands.
what is the work round for this?
many thanks to all
Posted: Tue May 17, 2011 9:52 am
Hello Barry,
