External reset for the ECIO40
Electron
Has thanked: 4 times
Post by Electron »
I want to be able to externally reset an ECIO40 with a switch. Pin 3 of the ECIO40 is labelled RESET. What voltage and/or circuitry do I need to add?
[the email notification does not seem to work, even though I have entered a valid email address in my profile]
Re: External reset for the ECIO40
You can simply add a switch between pin 3 and ground.
If you want to reduce the switch's contact bounce (not mandatory) then you can also fit a ceramic capacitor across the switch.
