I had not this problem in simulation before the upgrade. Buttons and switches had instantly response when pressed. After the upgrade to v4.5, they remain inactive for 2 - 3 sec. Try please the attached fcf.
Please advise me
Fotios
Simulator problem after FCv 4.5 upgrade
- fotios
- Has thanked: 109 times
- Been thanked: 117 times
- PGA2310preamp_v1.2.fcf
- (81.49 KiB) Downloaded 276 times
Best Regards FOTIS ANAGNOSTOU
Re: Simulator problem after FCv 4.5 upgrade
Hello Fotios,
Changing the simulation speed to as fast as possible in the View -> Project options menu seems to help in speeding the switch components up again.
- fotios
I already tried in full speed many times (i did the upgrade from yesterday the night) but the problem still exists. When a button is pressed (not in all instances) i have to wait for a while - say 3-4 sec - for the same or another button or switch to be available for activation. I also have glitches in steps - i.e. jumps from e.g. 80 to 82 - that i had not with the previous version of FlowCode.
Fotios
Fotios
- fotios
Hello Ben
To be sure, I just uninstalled FC v4.5 and reinstalled the previous FC v4.3. Now everything is again working just fine in SIMULATOR. No dead time - of some seconds - in activation of switches, no glitches in program steps.
Best Regards
Fotios
Best Regards
Fotios
Hello Fotios,
We have been able to replicate the problems you are referencing and we are looking into the cause.
- fotios
Hello Ben
Thanks for the reply. Since i don't want to cause - possibly - unreasonable research work to you, I should refer that this project although is properly working on SIMULATOR, in actual hardware (EB006 + LCD module + Switch board + LED board) presents hang-up when the MENU switch is pressed for 3rd time. I am trying it for 3 days on a P16F887. Yesterday i replaced the micro with a P18F4520 and the hang-up eliminated, the code is working properly with this micro ON ACTUAL HARDWARE. I have a suspicion - from the few things that i know about micros - that P16F887 presents a "Stack Overflow" in ACTUAL MODE due to its small proram memory. I don't know if this will help you in examining of problem of SIMULATOR.
Fotios
Fotios
- fotios
I must apologize for the possible misunderstanding that I caused.
The problem was the inappropriate structure of my program - for micros with small stack depth like the PIC16Fxxx - and not the FlowCode simulator after the upgrade to v4.5.
The FCv4.5 simulator works correctly and better than the previous version by providing possible errors - of the type that I described above - on the actual hardware.
Thanks for the assistance to MatrixMultimedia tech team, and please accept my apologies.
Fotios
Fotios
