Flowcode 4 student upgrade to Pro
Posted: Wed Sep 07, 2011 5:18 am
by Leong NyukWah
HI,
Sorry I have to make use of this forum as I do not know where to call for help. Recently I had received upgrade version to Pro FC CD. When I run the CD in my PC, it does not ask for the activation licence code, instead it asks to select for modify, repair or remove. When I select modify, it just run through and complete the installation. I made a trail run to compose hex file on which contains EEPROM data usage. The result indicate I am still having an student type FC instead of the Pro version. Please kindly let me know whether I am receiving the wrong CD or I have to delete the current FV4 student version in my PC prior to install the new Pro version? There is a print letter on the CD marking TEFLC4, is this indicate it is a student version instead of Pro.?
Re: Flowcode 4 student upgrade to Pro
Posted: Wed Sep 07, 2011 8:29 am
by Steve
There is no need to reinstall.
In Flowcode, select the "help...register" menu and enter the new code in the "CD code" box (do this for v4.5 and later) or in the "key" box whilst leaving the "name" box blank (pre v4.5).
Your copy of Flowcode will then become the "professional" version. You should then activate this code via our website.
Posted: Wed Sep 07, 2011 9:36 am
by Leong NyukWah
Hi, Steve,
Sorry to trouble you again, you did mentioned about the "help..register" menu in your mail. By the way where can I find the"help..register" menu? Is it in the FC CD supplied or on the matrix web site? I can't locate this menu at the supplied CD. Please kindly indicate where to look for the help menu.
TQ
Posted: Wed Sep 07, 2011 9:39 am
by Steve
It is within Flowcode itself.
