Basic installation/driver problems PPP3
Posted: Mon Dec 05, 2011 9:24 am
Hi all,
This is what i have done so far.
Bought the EB006 in november 2011, my invoice says version 7 but it doesnt like the one of the picture in the datasheet;
_i have 3 caps by the USB connector instead of 2 chips on the picture
_I have 6 headers instead of the ICD2 socket
I have installed the PPP3 software from the CD (using Win7 32bits)
The installation is going ok but once i run the soft i have a message that a NTPORT.dll is missing.
if i dont uninstall it and i install the "old version3.9" still provided in the CD
the installation is slightly different but it works. altough i have a warning "DPinst.exe does not execute on your current system"
however the PPP program now is running.
once the old version installed I can run the newest version. i have in the "about" section, Version 3.11.15.30 Firmware version 8
in the windows device manager i have under "Custom USB Devices", "Matrix PICmicro Programmer" without any alert or warnings
now here comes the problem of communication
just using PPP3 (no FlowCode)
using a 16F877A
using USB power only (J11 on left position)
J12, J13, J14 on the USB position (right, towards the center of the board)
J18, J19 on OSC (left position)
SW2 on RC
SW1 on Slow (fast makes no difference)
I configure the PPP3 with Chip PIC16F877A, RC, Watchdog OFF (the Autodetect says "PIC16F74 was not found in this list, please use Expert config screen")
in the Expert Config, Autodetect will change pic to 16F74" although it was a 16F877A in the comboBox
If i click agin it will display "Could not ID the onboard chip"
So I leave the 16F877A and make sure the LVP is ON, Oscillator on RC
If i try to erase, it says "PICmicro has not been erased retry another 10 times".
If i try to send the RC-LVP.hex from the test files, it says "Could not ID the onboard chip - assuming it's the one specified in the configuration screen ie PIC16F877A"
but if i clcik OK, I have "Hex file has Config2 word, but selected chip does not, continue?", then i have "Picmicro has not been erased, Continue?", yes again and then
i have "Programming failed: <config1>
Well as you can see I have ONLY problems
so thanks a lot for any help...
I have also tried with a Windows 7 64 and I have same messages
Trying to write down step by step what is going on was really hard as it rarely do the same thing twice in a row!
sometimes i have "Device not recognized, please enter the name"
Thanks for any help
using a 16F877A
SW2 on RC
Thanks for any help
