Another Bluetooth module
Posted: Mon Dec 19, 2011 10:06 am
by Marcel
I have a LinkMatik bluetooth module from FlexiPanel. How can I set up this module as a generic serial communication bus, same as the Ezurio bluetooth module. Can I program it with the example 1 program from the bluetooth bundle ?
Kind Regards, Marcel
Re: Another Bluetooth module
Posted: Mon Dec 19, 2011 11:32 am
Hello Marcel.
Does the module your using use AT commands? If so then there should be a datasheet or similar for the module that lists all of the specific AT commands and their functions. Then maybe check against the scripts in the example and see if the commands seem correct.
I would think that a bluetooth module is a bluetooth module is a bluetooth module and so all commands should work the same and follow the Bluetooth specification but I could be wrong on this.
