RS232
brunoflow
RS232
Post by brunoflow »
I would like to help in an RS232 communication
I use Windows 7. hyperterminal use a separate program.
I can not send and receive the same information.
thank you
brunoflow
Re: RS232
Post by brunoflow »
2. Simple Echo 16F877A-picgenios.fcf
(6.5 KiB) Downloaded 338 times
Re: RS232
Hi brunoflow,
If you right click on your RS232 on your control panel and select Ext properties.
Try changing from Bytes to Characters in the Simulation part.
brunoflow
Re: RS232
Post by brunoflow »
The problem is the time to emulate the hardware when I send a post by my hyperterminal value it returns another ex: 890 and sent me back 80 or 980.
It's all right configurate the time the crystal?
and I doubt this is because this type of error?
Re: RS232
Ah I see.
What I suggested is correct for simulation, But for the hardware side, go back to Ext properties. and change Char receive type from Int to byte.
Then you should receive correct characters
Probably what I would do is when type a message, I would fill LCD from left to right, then when get to the far right of LCD, start scrolling text .
brunoflow
Re: RS232
Post by brunoflow »
Hello Martin
I changed how he had explained to me and left the way it was, just that when I use my USART terminal continues giving error
I send and receive 80 to 809
command again when I get 809 980 and is thus like to know what's happening and the error in my program that is configured crsital this right?
brunoflow
Re: RS232
Post by brunoflow »
medelec35 wrote:Ah I see.
Hello Martin
has some hyperterminal for windows 7?
brunoflow
Re: RS232
Post by brunoflow »
Hello Martin
Maybe you can help me, I'm doing a cominicação via RS232 only when I record on my hardware it does wrong transmission wonder what would be the problem?
(91.14 KiB) Downloaded 3095 times
Re: RS232
brunoflow wrote: has some hyperterminal for windows 7?
Hi brunoflow,
Two such programs was mentioned here:
http://www.matrixmultimedia.com/mmforum ... 563#p30563
I tried your flowchart with hyperterminal. After changing it as I suggested, when I pressed letter K on pc, then LCD also showed K.
What about just sending ASCII and have support for ASCII selected?
brunoflow wrote:Hello Martin
What software are you using for comms?
brunoflow
Re: RS232
Post by brunoflow »
thank you
using SerialPort not work what is the problem?
It set up the crystal, where I am making a mistake.
(28.87 KiB) Downloaded 3092 times
brunoflow
Re: RS232
Post by brunoflow »
When sending the number 90 does not return anything if I keep pressing several times in this way is like a help to know if the Flowcode works with serial communication or it only works in the simulation?
brunoflow
Re: RS232
Post by brunoflow »
I managed to solve my problem. I am sending the code if someone has solved the same doubts I had.
2. Simple Echo 16F877A.fcf
(6.5 KiB) Downloaded 302 times
