Formula AllCode with Java
Java is a very commonly used programming language and is used on many devices from your mobile phone to your PC to your car.
To get started with Java you first need to download and install a Java SE Development Kit or JDK. I downloaded Java SE Development Kit 8u91 which is Java version 8 update 91.
Once the JDK is installed you can verify it is setup correctly by clicking start and running CMD.
In the command terminal type in the following commands and both should return the same number which confirms that the JDK is operational and correctly setup.
java -version
javac -version
The java command line is what we use to run a program and the javac is what we use to compile a java program.
Using a text editor I created my first simple program Hello.java.
class Hello
    public static void main (String[] args)
        System.out.println(“Hello World”);
I compiled this by using the CMD window. I navigated to the directory containing my source code and then ran the following line to compile the code.
javac Hello.java
To run the code I simply type the following command.
java Hello
On doing this I get the message “Hello World” appearing in the command window.
The next program starts to use serial communications. To do this I used the jssc library which can be downloaded from here.
https://github.com/scream3r/java-simple-serial-connector/releases
You just need the file jssc.jar to be in the same folder as your java source code.
import jssc.*;
class AllCode
        System.out.println(“Opening Port”);
        //Assign the COM port number we wish to open
        SerialPort serialPort = new SerialPort(“COM32”);
        try
            //Open The Port
            System.out.println(“Port Opened: ” + serialPort.openPort());
            //Setup The Port
            System.out.println(“Port Setup: ” + serialPort.setParams(SerialPort.BAUDRATE_115200,
                                 SerialPort.DATABITS_8,
                                 SerialPort.STOPBITS_1,
                                  SerialPort.PARITY_NONE));
            //Writes data to port
            serialPort.writeBytes(“LCDClear;”.getBytes());
            serialPort.writeBytes(“LCDPrint 0 0 Hello World;”.getBytes());
            //Closing the port
            serialPort.closePort();
        catch (SerialPortException ex)
            System.out.println(ex);
You then compile the project using this command line.
javac -cp jssc.jar AllCode.java
And finally run the project using this command line on a Windows machine, other operating systems may differ.
java -cp .;jssc.jar AllCode
Here is the same program but this time using functions to drive various aspects of the robot to provide a more modular way of working.
import jssc.*;
class AllCode
        //Open Port
        COM_Open(serialPort);
        //Collect Light Level and save to variable
        int Light = ReadLight(serialPort);
        //Send Commands to the FA Robot
        //Clear LCD
        LCDClear(serialPort);
        //Print Light Level to LCD
        LCDPrint(serialPort, “Light: ” + String.valueOf(Light), 0, 8);
        //Print Light Level to Command Window
        System.out.println(“Light: ” + String.valueOf(Light));
        //Close the port
        COM_Close(serialPort);
    //Port Functions
    private static void COM_Open(SerialPort serialPort)
        try
            //Open The Port
            //Setup The Port
    private static void COM_Close(SerialPort serialPort)
        try
            serialPort.closePort();;
    private static int ReadLight(SerialPort serialPort)
        int retval = 0;
        try
            serialPort.writeBytes(“ReadLight;”.getBytes());
            retval = ConvertInDataToInt(serialPort, 4);
        return retval;
    //LCD Functions
    private static void LCDClear(SerialPort serialPort)
        try
    private static void LCDPrint(SerialPort serialPort, String data, int x, int y)
        String dataOut = “LCDPrint ” + x + ” ” + y + ” ” + data + “;”;
        try
            serialPort.writeBytes(dataOut.getBytes());
A more complete version of the Java code can be found on the Formula AllCode Downloads page.
Loading
Leave a Reply
