From prototyping to real-world applications in one step
miac_bannermiac_newlogoFROM PROTOTYPING TO REAL WORLD APPLICATIONS IN ONE STEP
Together with many thousands of other electronics enthusiasts you receive this mail with the latest updates from the engineer’s desk of Matrix.
If you are active in teaching or designing electronics you will be aware of the gap between testing, trying out, and bringing prototypes into real world applications. When we started designing the MIAC product line the first question was: where, in the real world, will this product be mounted? As a result of that thinking you will find a 35mm ‘top hat’ DIN rail connector on the back of all our MIAC models. The MIAC will live a hidden life, mounted away in a ‘dark’ electrical cabinet, doing its duty. With this in mind, the MIAC has a Backlit LCD display – no need to bring a flashlight for maintenance!
In this ‘dark’ cabinet, the MIAC will face typical industrial voltage signals. With 0 -10V inputs, up to MIAC ICONS24V motor outputs, 240V switching relays, 8 analogue or digital inputs, 4 high current relay outputs and 4 solid state outputs, the MIAC range has been designed to work under all signal conditions.
Other features include a fully operational CAN bus interface so that many MIACs can be networked together to form wide area electronic systems. The CAN bus parameters are adjustable, so as to interface to existing networks. Several of the range also feature RS232 and RS485 serial communication interfaces.
PINK, YELLOW, BLUE, GREEN
Recently we developed a new range of MIAC products and we are happy to present to you the Raspberry Pi (Pink), Arduino (Blue) and the dsPIC (Yellow) powered MIACs, alongside the existing 8-bit PIC version (Black). This means you (or your students) can use the MIAC with the platform you prefer and are familiar with. The full specifications of the MIAC product line can be found here
REAL WORLD APPLICATIONS WITH A REAL WORLD DISCOUNT
The MIAC allows you to prototype your design and use it straight away in your power control application. If you are interested in testing, trying and using a MIAC yourself we are happy to offer you a 10% discount on your purchase for a limited time only. Visit our website now to take advantage of this special offer.  Offer available until Jan 5, 2017.
For pricing and ordering visit: http://www.matrixtsl.com/miac/base/
Thank you
The Matrix team
Loading
Leave a Reply
