Storage solutions
Most of our kits at Matrix, come supplied in rugged and stack-able Gratnells trays, with lids. The benefit of this is that the kit can easily be packed away and stored in a class room environment so that it is not in the way of other classes and desks are not required permanently to store kit on top of when it is not being used. Classrooms can become more versatile and make much more use of the space available, opposed to some other kit on the market, which requires a permanent space to be set up.
In addition, parts are stored neatly where possible into foam inserts to ensure that they are safe from damage and also makes it easy when packing away to ensure that no kit is missing. Kits also come clearly labelled with a bill of materials to ensure easy stock checking.
Under the foam insert, there is a inlay sheet which also has an easy picture reference for each part in the kit. This makes it really easy to match up where each component should be in the tray and identify what may be missing.
If you have any questions about storage solutions or anything else, please do not hesitate to contact us here!
