MediaWiki API help
This is an auto-generated MediaWiki Action API documentation page.
action=move
(main | move)
- This module requires read rights.
- This module requires write rights.
- This module only accepts POST requests.
- Source: MediaWiki
- License: GPL-2.0-or-later
Move a page.
Specific parameters:
Other general parameters are available.
- from
Title of the page to rename. Cannot be used together with fromid.
- fromid
Page ID of the page to rename. Cannot be used together with from.
- Type: integer
- to
Title to rename the page to.
- This parameter is required.
- reason
Reason for the rename.
- Default: (empty)
- movetalk
Rename the talk page, if it exists.
- Type: boolean (details)
- movesubpages
Rename subpages, if applicable.
- noredirect
Don't create a redirect.
- watchlist
Unconditionally add or remove the page from the current user's watchlist, use preferences (ignored for bot users) or do not change watch.
- One of the following values: nochange, preferences, unwatch, watch
- Default: preferences
- ignorewarnings
Ignore any warnings.
Change tags to apply to the entry in the move log and to the dummy revision on the destination page.
- Values (separate with | or alternative): Flowcode v8, Flowcode v9, Flowcode v10, Version
- token
A "csrf" token retrieved from action=query&meta=tokens
Example:
- Move Badtitle to Goodtitle without leaving a redirect.
- api.php?action=move&from=Badtitle&to=Goodtitle&token=123ABC&reason=Misspelled%20title&movetalk=&noredirect= [open in sandbox]
