Component: Output Digital (DSP Outputs)
(Redirected from Component: ID 1392d5c3 35ba 4c7f a539 7f30a09758e4)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.2 |
Category | DSP Outputs |
Output Digital component
Allows the values from a buffer to be read. Either a value at a time or as an array.
Please click here to download the component source project: FC_Comp_Source_DSP_Output.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Output.fcfx
GetByte
GetByte | |
Returns a byte value from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
- BYTE | Return |
GetByteArray
GetByteArray | |
Returns an array of byte values from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
- BYTE | Data |
- UINT | Count |
- VOID | Return |
GetFloat
GetFloat | |
Returns a float value from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
- FLOAT | Return |
GetFloatArray
GetFloatArray | |
Returns an array of float values from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
- FLOAT | Data |
- UINT | Count |
- VOID | Return |
GetInt
GetInt | |
Returns an integer value from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
- UINT | Return |
GetIntArray
GetIntArray | |
Returns an array of integer values from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
- UINT | Data |
- UINT | Count |
- VOID | Return |
GetLong
GetLong | |
Returns a long value from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
- ULONG | Return |
GetLongArray
GetLongArray | |
Returns an array of long values from the specified buffer. Auto increments the read location if the buffer size is greater than 1. | |
- ULONG | Data |
- UINT | Count |
- VOID | Return |
