Author
Matrix Ltd
Version
1.4
Category
Rotary Angle Sensor (Grove 101020017) component
The Rotary Angle sensor is based on a simple analogue potentiometer.
Please click here to download the component source project: FC_Comp_Source_Rotary_Angle_Sensor.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Rotary_Angle_Sensor.fcfx
Start Angle
Sweep Angle
Color
Colour of the pointer.
Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
