Component: Formula AllCode API (AllCode)
(Redirected from Component: ID 4182ece3 6ad5 41d3 a0e2 31bc570806db)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.2 |
Category | AllCode |
- 1 Formula AllCode API component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 Backwards
- 5.2 CardBitmap
- 5.3 CardCreate
- 5.4 CardErase
- 5.5 CardInit
- 5.6 CardOpen
- 5.7 CardPlayback
- 5.8 CardReadByte
- 5.9 CardRecordMic
- 5.10 CardWriteByte
- 5.11 EncoderRead
- 5.12 EncoderReset
- 5.13 Forwards
- 5.14 GetConsoleHandle
- 5.15 GetProp
- 5.16 LCDBacklight
- 5.17 LCDClear
- 5.18 LCDDrawLine
- 5.19 LCDDrawPixel
- 5.20 LCDDrawRect
- 5.21 LCDPrintNumber
- 5.22 LCDPrintString
- 5.23 LCDVerbose
- 5.24 LEDOff
- 5.25 LEDOn
- 5.26 LEDWrite
- 5.27 Left
- 5.28 PlayNote
- 5.29 ReadAllSensors
- 5.30 ReadAllValue
- 5.31 ReadAxis
- 5.32 ReadBearing
- 5.33 ReadIR
- 5.34 ReadLight
- 5.35 ReadLine
- 5.36 ReadMic
- 5.37 ReadSwitch
- 5.38 Right
- 5.39 SampleAccel
- 5.40 SampleMag
- 5.41 ServoAutoMoveToPosition
- 5.42 ServoDisable
- 5.43 ServoEnable
- 5.44 ServoSetAutoMoveSpeed
- 5.45 ServoSetPosition
- 5.46 SetLogoSpeed
- 5.47 SetMotors
- 5.48 SetProp
- 6 Property reference
A simulation only component to allow the Formula AllCode robot to be controlled via it's API interface and Bluetooth data connection without having to compile or re-program the robot.
Please click here to download the component source project: FC_Comp_Source_FormulaAllCode_API.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_FormulaAllCode_API.fcsx
Backwards
Backwards | |
Drives the robot backwards - waits for the distance to be traversed before returning | |
- UINT | Distance |
Distance in mm | |
- VOID | Return |
CardBitmap
CardBitmap | |
Displays a monochrome bitmap read from the card on the LCD | |
- BYTE | X |
Range 0-127 | |
- BYTE | Y |
Range 0-31 | |
- STRING | Filename |
- BYTE | Return |
CardCreate
CardCreate | |
Attempts to create a file on the SD card 255=Error, 1=File Already Exists, 0=Create OK | |
- BYTE | Return |
CardErase
CardErase | |
Attempts to delete an existing file on the SD card 255=Error, 1=File not found, 0=Delete OK | |
- BYTE | Return |
CardInit
CardInit | |
Attempts to startup the SD card 255=No Card, 254=Init Fail, 0=Init OK | |
- BYTE | Return |
CardOpen
CardOpen | |
Attempts to open an existing file on the SD card 255=Error, 1=File not found, 0=Open OK | |
- BYTE | Return |
CardPlayback
CardPlayback | |
Plays back a .Wav file audio stream from the card | |
- BYTE | Return |
CardReadByte
CardReadByte | |
Reads a byte from the currently open file. Starts at the beginning of the file and auto increments to the end | |
- BYTE | Return |
CardRecordMic
CardWriteByte
CardWriteByte | |
Appends a byte to the end of the currently open file | |
- BYTE | Data |
- VOID | Return |
EncoderRead
EncoderRead | |
Reads one of the motor encoder counters. Approx 0.328296mm of travel per encoder unit. | |
- BYTE | index |
0=Left, 1=Right | |
- UINT | Return |
EncoderReset
EncoderReset | |
Resets the motor encoder counters | |
- VOID | Return |
Forwards
Forwards | |
Drives the robot forwards - waits for the distance to be traversed before returning | |
- UINT | Distance |
Distance in mm | |
- VOID | Return |
GetConsoleHandle
GetConsoleHandle | |
Gets the handle to the console allowing data displaying on the panel etc. | |
- HANDLE | Return |
GetProp
GetProp | |
Allows the property filter for the COM port list to be copied to a parent component. | |
- STRING | PropName |
- STRING | Return |
LCDBacklight
LCDBacklight | |
Allows the LCD backlight brighntess to be adjusted | |
- BYTE | Intensity |
Range 0-100, 0=Off, 1=Min Brightness, 100=Max Brightness | |
- VOID | Return |
LCDClear
LCDClear | |
Clears the LCD | |
- VOID | Return |
LCDDrawLine
LCDDrawLine | |
Allows a single pixel width line to be drawn on the LCD | |
- BYTE | X1 |
X Pixel 0-127 | |
- BYTE | Y1 |
Y Pixel 0-31 | |
- BYTE | X2 |
X Pixel 0-127 | |
- BYTE | Y2 |
Y Pixel 0-31 | |
- VOID | Return |
LCDDrawPixel
LCDDrawPixel | |
Allows a single pixel on the LCD to be set or cleared | |
- BYTE | X |
X Pixel 0-127 | |
- BYTE | Y |
Y Pixel 0-31 | |
- BYTE | State |
0=White (Off), 1=Black (On) | |
- VOID | Return |
LCDDrawRect
LCDDrawRect | |
Allows a rectangle to be drawn on the LCD | |
- BYTE | X1 |
X Pixel 0-127 | |
- BYTE | Y1 |
Y Pixel 0-31 | |
- BYTE | X2 |
X Pixel 0-127 | |
- BYTE | Y2 |
Y Pixel 0-31 | |
- VOID | Return |
LCDPrintNumber
LCDPrintNumber | |
Prints a 16-bit signed number to the LCD | |
- BYTE | X |
X Pixel 0-127 | |
- BYTE | Y |
LCD Y coordinate 0-31 | |
- INT | Number |
Range -32768 to 32767 | |
- VOID | Return |
LCDPrintString
LCDPrintString | |
Prints a string to the LCD | |
- BYTE | X |
X Pixel 0-127 | |
- BYTE | Y |
LCD Y Coordinate 0-31 | |
- STRING | Data |
- VOID | Return |
LCDVerbose
LCDVerbose | |
Allows the LCD to automatically report the API commands as they get processed. Default - verbose on | |
- BYTE | State |
0=Off 1=On | |
- VOID | Return |
LEDOff
LEDOff | |
Clears a single LED 0-7 | |
- BYTE | index |
Range: 0-7 | |
- VOID | Return |
LEDOn
LEDOn | |
Sets a single LED 0-7 | |
- BYTE | index |
Range: 0-7 | |
- VOID | Return |
LEDWrite
LEDWrite | |
Sets the value of the LEDs as an 8-bit output | |
- BYTE | Value |
LED value 0=All Off, 255 = All On | |
- VOID | Return |
Left
Left | |
Rotates the robot left - waits for the angle to be traversed before returning | |
- UINT | Angle |
Angle to turn in degrees | |
- VOID | Return |
PlayNote
PlayNote | |
Plays a note using the speaker on the FA | |
- UINT | Note |
Range 1 to 65535 in Hz | |
- UINT | Delay |
Number of milliseconds to play the note for | |
- VOID | Return |
ReadAllSensors
ReadAllSensors | |
Samples all of the robot's sensors at once, storing the values locally | |
- VOID | Return |
ReadAllValue
ReadAllValue | |
Reads a single value stored from the read all command Index dictates which sensor value to read | |
- BYTE | Index |
0=SW, 1-8=IR, 9-10=Line, 11=Light, 12=Mic, 13-15=Accel | |
- UINT | Return |
ReadAxis
ReadAxis | |
Reads a single X/Y/Z axis from the accelerometer sensor. | |
- BYTE | index |
0=X, 1=Y, 2=Z | |
- INT | Return |
ReadBearing
ReadBearing | |
Reads the compass bearing based on the degrees clockwise from magnetic north. | |
- INT | Return |
ReadIR
ReadLight
ReadLight | |
Reads the light sensor 0-4095 - 4095 = Max Brightness | |
- UINT | Return |
ReadLine
ReadLine | |
Reads one of the IR line sensors 0-1 0=Left, 1=Right | |
- BYTE | index |
0=Left, 1=Right | |
- UINT | Return |
ReadMic
ReadMic | |
Reads the microphone sensor 0 - 4095 | |
- UINT | Return |
ReadSwitch
ReadSwitch | |
Read the switch value | |
- BYTE | index |
0 (left) or 1 (right) | |
- BYTE | Return |
Right
Right | |
Rotates the robot right - waits for the angle to be traversed before returning | |
- UINT | Angle |
- VOID | Return |
SampleAccel
SampleAccel | |
Samples the accelerometer 0 = no new data, 1 = new data available | |
- BYTE | Return |
SampleMag
SampleMag | |
Samples the magnetometer 0 = no new data, 1 = new data available | |
- BYTE | Return |
ServoAutoMoveToPosition | |
Allows one of the servo positions to move gradually to a new position | |
- BYTE | Channel |
Range 0-3 | |
- BYTE | Position |
Range 0-255 | |
- VOID | Return |
ServoDisable
ServoDisable | |
Allows one of the servo outputs 0-3 to be disabled | |
- BYTE | Channel |
Range 0-3 | |
- VOID | Return |
ServoEnable
ServoEnable | |
Allows one of the servo outputs 0-3 to be enabled | |
- BYTE | Channel |
Range 0-3 | |
- VOID | Return |
ServoSetAutoMoveSpeed | |
Changes the speed of the auto movements Default - 1 | |
- BYTE | Speed |
Range 1-50 | |
- VOID | Return |
ServoSetPosition
ServoSetPosition | |
Allows one of the servo positions to be assigned | |
- BYTE | Channel |
Range 0-3 | |
- BYTE | Position |
Range 0-255 | |
- VOID | Return |
SetLogoSpeed
SetLogoSpeed | |
Sets the speed of logo movements | |
- BYTE | Speed |
Logo Speed 1-100 - Default 40 | |
- VOID | Return |
SetMotors
SetMotors | |
Sets the motor speeds without feedback Range -100 to 100 | |
- INT | Left |
- INT | Right |
- VOID | Return |
SetProp
SetProp | |
Allows the COM port property to be set from a parent component. | |
- ULONG | PropVal |
- VOID | Return |
