Component: GLCD Monochrome (BL0139) (E-blocks 2)
Category E-blocks 2
GLCD Monochrome component
Graphical display component designed to work with the EB2 BL0139 Downstream E-block.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_Mono_GLCD_BL0139.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_Mono_GLCD_BL0139.fcfx
BPlot
Fc9-comp-macro.png BPlot
Fc9-u8-icon.png - BYTE X1
Fc9-u8-icon.png - BYTE Y1
ClearDisplay
DrawCircle
Fc9-comp-macro.png DrawCircle
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-u8-icon.png - BYTE Solid
DrawEllipse
DrawLine
Fc9-comp-macro.png DrawLine
Fc9-u8-icon.png - BYTE X2
Fc9-u8-icon.png - BYTE Y2
DrawRectangle
Goto_XY
Fc9-comp-macro.png Goto_XY
Fc9-comp-macro.png Initialise
Plot
Fc9-comp-macro.png Plot
Print
Fc9-comp-macro.png Print
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u8-icon.png - BYTE Font
Fc9-s16-icon.png - INT Number
ReadFontStat
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
SetBackgroundColour
Fc9-u8-icon.png - BYTE PixelColour
0=White, 1=Black
SetDisplayOrientation
SetFontScaler
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
SetForegroundColour
0=White, 1=Black
Write_Command
Fc9-comp-macro.png Write_Command
Fc9-u8-icon.png - BYTE Command
Write_Data
Fc9-comp-macro.png Write_Data
Fc9-u8-icon.png - BYTE data
Fc9-type-16-icon.png Version
Fc9-conn-icon.png Dimensions
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-5-icon.png CS
Chip select pin
Fc9-type-5-icon.png Reset
Fc9-type-5-icon.png A0
Fc9-type-5-icon.png Data Pin
Fc9-type-5-icon.png Clock Pin
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Display Method
Fc9-type-15-icon.png Component Label Scale
