Component: Serial EEPROM (24LC512) (EEPROM)
Version 2.2
Category EEPROM
Serial EEPROM (24LC512) component
Serial (I2C) EEPROM component for 24LC512
Please click here to download the component source project: FC_Comp_Source_Serial_EEPROM_(24LC512).fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Serial_EEPROM_(24LC512).fcfx
Read
Fc9-comp-macro.png Read
Read and return the value of the EEPROM at the given address
Fc9-u16-icon.png - UINT address
ReadPage
Fc9-comp-macro.png ReadPage
Reads and return specified number of values of the EEPROM starting from the given address
Fc9-u8-icon.png - BYTE data
Fc9-u8-icon.png - BYTE count
Write
Fc9-comp-macro.png Write
Write the given data value to the EEPROM at the given address
WritePage
Fc9-comp-macro.png WritePage
Writes up to 128 data values to the EEPROM at the given address
Range: 1-128
Fc9-type-16-icon.png Device Address
Device address bits, these must match the address pins on the EEPROM IC.
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png Simulation
No - Provides simulation using a local memory buffer Yes - Provides I2C simulation which can be passed via an API device to real world hardware
