Component: API (BL0032) (API Slave Devices)
Version 2.1
Category API Slave Devices
API (BL0032) component
Connects to an BL0032 dsPIC running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / UART / PWM See Flowcode Help Wiki for firmware.
Please click here to download the component source project: FC_Comp_Source_BL0032_API_Comp.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_BL0032_API_Comp.fcfx
The App Developer (BL0032 dsPIC E-Block) component allows an BL0032 dsPIC E-block board to be controlled from within the Flowcode simulation runtime.
To allow Flowcode to communicate and control the Arduino Uno hardware the board must first be pre-programmed with dedicated firmware.
The firmware hex file and Flowcode source project can be downloaded from here.
ZIP Icon.png BL0032 dsPIC App Developer Firmware
The USB should be connected to the Target port on the E-block board to allow Flowcode to communicate with the Target microcontroller.
The COM port to the E-block hardware is selected via the SCADA_BL0032 component COM port property.
When building the component into a App Developer project remember to expose the COM port property to allow the end user to select the correct port for the hardware.
  • fixed statistics showing IO / ADC inputs / PWM
  • scrolling log showing all commands and returns
Pin Mapping
Here is a table showing how the slave digital pins are mapped on the device.
App Developer Slave Digital Pin 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
Device Port Pin B0 B1 B2 B3 B4 B5 B6 B7 B8 B9 B10 B11 B12 B13 B14 B15 D0 D1 D2 D3 D4 D5 D6 D7 E0 E1 E2 E3 E4 E5 E6 E7 F0 F1 F3 F4 F5 C13 C14 D8 D9 D10 D11 G6 G7 G8 G9
Here is a table showing how the slave analogue pins are mapped on the device.
App Developer Slave Analogue Pin 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
Device Port Pin B0 B1 B2 B3 B4 B5 B6 B7 B8 B9 B10 B11 B12 B13 B14 B15 E0 E1 E2 E3 E4 E5 E6 E7
Here is a table showing how the slave peripheral pins are mapped on the device.
App Developer Slave Peripheral Pin I2C 0 SDA I2C 0 SCL I2C 1 SDA I2C 1 SCL SPI 0 MOSI SPI 0 MISO SPI 0 SCK SPI 1 MOSI SPI 1 MISO SPI 1 SCK SPI 2 MOSI SPI 2 MISO SPI 2 SCK SPI 3 MOSI SPI 3 MISO SPI 3 SCK UART 0 RX UART 0 TX UART 1 RX UART 1 TX UART 2 RX UART 2 TX UART 3 RX UART 3 TX
Device Port Pin D9 D10 F4 F5 D3 D4 D5 G8 G7 G6 E0 E1 E2 F3 F4 F5 F0 F1 D0 D1 G9 G8 G7 G6
App Developer Slave Peripheral Pin PWM 0 PWM 1 PWM 2 PWM 3 PWM 4 PWM 5 PWM 6 PWM 7 PWM 8 PWM 9 PWM 10 PWM 11 PWM 12 PWM 13 PWM 14 PWM 15
Device Port Pin D0 D1 D2 D3 D4 D5 D6 D7 F0 F1 F3 F4 F5 E0 E2 E4
ADCSample12
Fc9-comp-macro.png ADCSample12
Reads the voltage present on an Analog pin as an 12-bit value range 0-4095
Fc9-u8-icon.png - BYTE ADCChannel
Range: 0-31 ... Channels 16-23 unimplemented
ADCSample8
Fc9-comp-macro.png ADCSample8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255
ADCSampleArray10
Fc9-comp-macro.png ADCSampleArray10
Range: 0-5
Fc9-u8-icon.png - BYTE SampleCount
Range: 1- 32
Fc9-u16-icon.png - UINT SampleDelay
Fc9-u16-icon.png - UINT Samples
ADCSampleArray8
Fc9-comp-macro.png ADCSampleArray8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255 Performs the selected number of samples with the selected time in microseconds in between samples and returns each sample in a single packet
Range: 0-5
Range: 1- 32
Fc9-u8-icon.png - BYTE Samples
8-bit samples returned from the function
ADCSampleAverage10
Fc9-comp-macro.png ADCSampleAverage10
Range: 0-5
Range: 1- 100
Fc9-u8-icon.png - BYTE SampleDelay
ADCSampleAverage8
Fc9-comp-macro.png ADCSampleAverage8
Range: 0-5
Range: 1- 100
ADCSetPrechargeTime
Fc9-comp-macro.png ADCSetPrechargeTime
Specifies the precharge time for the ADC input readings in microseconds. The longer the time the more immune to noise the reading will be.
Fc9-u8-icon.png - BYTE ChargeTime
Default 10
ADCSetReferenceVoltage
Fc9-comp-macro.png ADCSetReferenceVoltage
Specified the reference setting for ADC reads.
Fc9-u8-icon.png - BYTE RefType
0=AREF, 1=VCC, 3=Internal 1.1V
I2CInitialise
Fc9-comp-macro.png I2CInitialise
Fc9-u8-icon.png - BYTE Baud
0=100KHz, 1=400KHz, 2=1MHz
I2CReceive
Fc9-comp-macro.png I2CReceive
Fc9-bool-icon.png - BOOL Last
I2CRestart
Fc9-comp-macro.png I2CRestart
I2CSend
Fc9-comp-macro.png I2CSend
I2CStart
Fc9-comp-macro.png I2CStart
I2CStop
Fc9-comp-macro.png I2CStop
I2CTransInit
Fc9-comp-macro.png I2CTransInit
Fc9-u8-icon.png - BYTE DeviceAddress
7-bit Device Address
I2CTransReceive
Fc9-comp-macro.png I2CTransReceive
Data variable to receive into
Fc9-u16-icon.png - UINT Count
Number of bytes to receive
I2CTransSend
Fc9-comp-macro.png I2CTransSend
Data to send
IOGetInputPin
Fc9-comp-macro.png IOGetInputPin
Fc9-u8-icon.png - BYTE Pin
Range: 0-47 ... Pin 34 unimplemented
IOSetOutputPin
Fc9-comp-macro.png IOSetOutputPin
Fc9-bool-icon.png - BOOL State
Range: 0-1
Fc9-comp-macro.png Initialise
PWMDisable
Fc9-comp-macro.png PWMDisable
Disable a PWM output
Range: 0-15
PWMEnable
Fc9-comp-macro.png PWMEnable
Enable a PWM output
Range: 0-15
PWMSetDuty
Fc9-comp-macro.png PWMSetDuty
Range: 0-15
Fc9-u8-icon.png - BYTE Duty
PWMSetPrescaler
Fc9-comp-macro.png PWMSetPrescaler
Range: 0-15
Fc9-u8-icon.png - BYTE Period
Default 255
RegisterRead
Fc9-comp-macro.png RegisterRead
Read one of the registers on-board the device
Fc9-u16-icon.png - UINT RegisterAddress
The address of the register
RegisterWrite
Fc9-comp-macro.png RegisterWrite
Writes to one of the registers on-board the device
Fc9-u16-icon.png - UINT Data
The data value to assign to the register
SPIInitialise
Fc9-comp-macro.png SPIInitialise
SPIPrescaler
Fc9-comp-macro.png SPIPrescaler
Range: 0-2
SPITransfer
Fc9-comp-macro.png SPITransfer
SPITransferTrans
Fc9-comp-macro.png SPITransferTrans
Outgoing data
Fc9-u8-icon.png - BYTE DataIn
Incoming data
UARTBaud
Fc9-comp-macro.png UARTBaud
Fc9-u8-icon.png - BYTE Rate
UARTCheckRX
Fc9-comp-macro.png UARTCheckRX
UARTInitialise
Fc9-comp-macro.png UARTInitialise
UARTReceive
UARTSend
Fc9-comp-macro.png UARTSend
Fc9-conn-icon.png Connection
Fc9-type-7-icon.png Auto Detect Port
Allows the component to auto detect the interface board COM port. Requires the latest Flowcode serial comms DLL to function correctly.
Fc9-type-16-icon.png COM Port
Lists all the current available COM port hardware on your PC.
Fc9-type-7-icon.png Refresh Ports
Fc9-conn-icon.png API Peripherals
Fc9-type-21-icon.png Digital IO
Fc9-type-21-icon.png Analog Input
Fc9-type-21-icon.png Analog Output
Fc9-type-21-icon.png PWM Output
Fc9-type-21-icon.png I2C Bus
Fc9-type-21-icon.png SPI Bus
Fc9-type-21-icon.png UART
Fc9-type-21-icon.png SERVO
Fc9-conn-icon.png Console
Fc9-type-7-icon.png Console Log
Create an automatic console log of the commands sent to the Arduino
Fc9-type-16-icon.png Log Mode
Controls how the console data is formatted. Fixed statistics gives an easy to read overview of the IO, Analog and PWM functionality Command Log gives a more in depth analysis of the outgoing commands and incoming returns
