Component: Network Communications (Comms: Networking)
(Redirected from Component: ID 91049bf5 2436 42dc 947a c30c86463d98)
Version | 1.5 |
Category | Comms: Networking |
Network Communications component
A component designed to simplify the process of TCP/IP communications. Compatible with most of the Flowcode supported TCP/IP and WIFI components. A useful building block for creating components such as IoT and Modbus TCP.
Please click here to download the component source project: FC_Comp_Source_NetworkComms.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_NetworkComms.fcfx
AcceptClose
AcceptClose | |
Goes with the AcceptOpen function to close the new thread handle. | |
- VOID | Return |
AcceptOpen
AcceptOpen | |
Required for systems where there can be multiple incoming threads Returns 1 if there is incoming comms requiring a new thread, else returns 0 | |
- BYTE | Return |
Connect
Initialise | |
Initialises the network communications component. | |
- VOID | Return |
Listen
Listen | |
Bind the socket to a port on the local host and set to listen mode. First Open a Socket on the local host Returns: 0=Fail, 1=OK | |
- UINT | Port |
Port number to listen on. | |
- BOOL | Return |
Receive
Send
SocketClose
SocketClose | |
Closes the current socket connection | |
- VOID | Return |
SocketOpen
SocketOpen | |
Attempts to create a socket on the local device. This must be succesful to allow TCP/IP communications with a remote destination. Returns: 0=Fail / 1=OK | |
- BOOL | Return |
