Component: Real Time Clock (ESP32) (Real Time Clock)
Category Real Time Clock
Real Time Clock (ESP32) component
Allows an ESP32 device to act as a RTC with NTP type server synchronisation. Requires a WIFI network connection with internet access to synchronise. Provides simulation using local PC system time.
Please click here to download the component source project: FC_Comp_Source_RTC_ESP32.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_RTC_ESP32.fcfx
A simple example that shows how to connect the ESP device to a network and synchronise the internal clock with an internet based NTP time server every hour.
FC6 Icon.png ESP32 RTC NTP Example
The internal clock can drift over time and so it is important to sync regularily with the NTP time server.
For low power operations or when internet connectivity may be intermittent a 32.768KHz crystal can be used with the ESP32 device to improve the internal clock accuracy over time.
The crystal is fitted between pins IO32 and IO33 and must have 12pF capacitors to ground. The crystal must also be enabled by editing the sdkconfig file in the project compilation directory.
GetDate
Fc9-comp-macro.png GetDate
Collects the day of the month as a numeric value in the range of 1 - 31.
GetDateString
Fc9-comp-macro.png GetDateString
Collects the current date and returns it as a string. e.g. "DD/MM/YY" or "MM/DD/YY"
Fc9-bool-icon.png - BOOL USFormat
Select date format: 0=DD/MM/YY, 1=MM/DD/YY
GetHours
Fc9-comp-macro.png GetHours
Collects the current hour as a numeric value in the range of 0 - 23.
GetMins
Fc9-comp-macro.png GetMins
Collects the current minute as a numeric value in the range of 0 - 59.
GetMonth
Fc9-comp-macro.png GetMonth
Collects the month as a numeric value in the range of 1 - 12.
GetSecs
Fc9-comp-macro.png GetSecs
Collects the current second as a numeric value in the range of 0 - 59.
GetTimeString
Fc9-comp-macro.png GetTimeString
Collects the current time and returns it as a string. e.g. "HH:MM" or "HH:MM:SS"
Fc9-bool-icon.png - BOOL IncludeSeconds
0=Dont Include Seconds, 1=Include Seconds in the String
GetYear
Fc9-comp-macro.png GetYear
Collects the year as a numeric value in the range of 0 - 99.
Fc9-comp-macro.png Initialise
Configures the timeserver variable as well as sets the timezone offset in seconds.
QueryTimeServer
Fc9-comp-macro.png QueryTimeServer
Attempt to collect the local time from the selected time server. The ESP WIFI must be connected to a network with internet to allow this to work. Returns true if the time server synchronised correctly with the ESP.
ReadDate
Fc9-comp-macro.png ReadDate
Fc9-u8-icon.png - BYTE Unit
ReadTime
Fc9-comp-macro.png ReadTime
SetDate
Fc9-comp-macro.png SetDate
Manually sets the current date. Useful for when WIFI / NTP commnication is not available.
Fc9-u8-icon.png - BYTE Date
Day of the month ranging from 1 to 31
Fc9-u8-icon.png - BYTE Month
Month ranging from 1 to 12
Fc9-u8-icon.png - BYTE Year
Year ranging from 0 to 99
SetTime
Fc9-comp-macro.png SetTime
Manually sets the current time. Useful for when WIFI / NTP commnication is not available.
Fc9-u8-icon.png - BYTE Hour
Hour ranging from 0 to 23
Fc9-u8-icon.png - BYTE Min
Minute ranging from 0 to 59
Fc9-u8-icon.png - BYTE Sec
Second ranging from 0 to 59
SetTimeServer
Fc9-comp-macro.png SetTimeServer
Overwrites the default time server setting allowing for multiple time servers to be queried.
Fc9-string-icon.png - STRING TimeServer
e.g. "pool.ntp.org"
SetUTCOffset
Fc9-comp-macro.png SetUTCOffset
Allows the UTC Offset to be defined in seconds. e.g. for BST use 3600 or for UTC+2 use 7200 or for UTC-2 use -7200
Fc9-s32-icon.png - LONG UTCOffset
Time offset in seconds
Fc9-type-10-icon.png Time Server
Default time server URL. Set as part of the initialise macro. Can be overridden using the SetTimeServer macro.
Fc9-type-21-icon.png UTC Offset
Offset in seconds from UTC. Set as part of the initialise macro. Can be overridden using the SetUTCOffset macro.
Fc9-type-21-icon.png Number of Retries
Sets the number of retries to connect to the SNTP server before giving up
