Component: Thermocouple (MAX31855) (Environmental)
(Redirected from Component: ID 97e631c7 51d9 4482 9b65 481b390a686d)
Version | 1.0 |
Category | Environmental |
Thermocouple (MAX31855) component
Component to interface the MAX31855 IC from MAXIM. Uses a standard 3-wire SPI interface to connect to the IC and collect the temperature. IC available in different versions to suit different thermocouple types.
Please click here to download the component source project: FC_Comp_Source_ThermocoupleMAX31855.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ThermocoupleMAX31855.fcfx
Example program showing how to use the Thermocouple component. MAX31855_Example
Initialise | |
Configures the SPI bus ready for communications. | |
- VOID | Return |
ReadReference_Float
ReadReference_Float | |
Returns the reference temperature from the last sample as a floating point value in Degrees C. | |
- FLOAT | Return |
ReadReference_Int
ReadReference_Int | |
Returns the reference temperature from the last sample as an integer value in Degrees C. | |
- INT | Return |
ReadThermocouple_Float
ReadThermocouple_Float | |
Returns the thermocouple temperature from the last sample as a floating point value in Degrees C. | |
- FLOAT | Return |
ReadThermocouple_Int
ReadThermocouple_Int | |
Returns the thermocouple temperature from the last sample as an integer value in Degrees C. | |
- INT | Return |
Sample
Sample | |
Reads the memory of the MAX31855 IC and checks for errors. Must be called before any of the Read functions. Returns: 0=OK, 1=Open Circuit, 2=Short GND, 3=Short VCC | |
- BYTE | Return |
