Component: Potentiometer (EBM002) (EBM Modules)
Version 1.1
Category EBM Modules
Potentiometer component
This board consists of a standard shaft rotary potentiometer that provides a linear voltage output ranging between the microcontroller power rails. This can be connected to an Analogue to Digital input of the microcontroller in order to provide a control value.
Please click here to download the component source project: FC_Comp_Source_EBM002v1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBM002v1.fcfx
This example simply reads the value from the potentiometer sensor component and outputs the value to an LCD as a number in the range 0-255.
FC6 Icon.png EBM002 Example
The ADC bit depth can be increased to 10 or 12 bit depending on your device by changing the Mode parameter to 1 in the ReadPotentiometer component macro.
ReadPotentiometer
Fc9-comp-macro.png ReadPotentiometer
Macro to read the potentiometer Mode = 0 will return a byte Mode = 1 will return an int
Fc9-bool-icon.png - BOOL Mode
0 = return BYTE, 1 = return INT
Fc9-s16-icon.png - INT Return
Fc9-type-6-icon.png Channel 1
Fc9-conn-icon.png Settings
+Vref voltage x 10mV Default 500 = 5V
Defines what is used as the ADC Vref source.
Clock setting to set how fast the ADC peripheral is driven.
Fc9-type-14-icon.png Aquisition cycles
