Component: Formula Flowcode (Robotics)
Version 2.0
Category Robotics
Formula Flowcode component
A component to allow all the features of the Formula Flowcode robot to be investigated. Fully simulated component which can interact with simulated objects on the panel as well as control the real hardware.
Please click here to download the component source project: FC_Comp_Source_FormulaFlowcode.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_FormulaFlowcode.fcfx
Importing from v5
The Formula Flowcode component in Flowcode v6 has a new Initialise macro which will need to be added to your program before any other calls to the component are made.
Line Following
Line following example using the Formula Flowcode, works with objects on the simulation panel and on the real hardware. FC6 Icon.png FF-Line FFLine.jpg
Maze Solving
Wall following example using the Formula Flowcode, works with a randomly generated maze on the simulation panel and on the real hardware. FC6 Icon.png FF-Maze Print3.jpg
CheckIR
Fc9-comp-macro.png CheckIR
Checks to see if a IR sensor is within the master threshold distance.
Fc9-u8-icon.png - BYTE Sensor
Forward
Fc9-comp-macro.png Forward
Drives both motors of the formula flowcode forwards with the power specified.
Fc9-u8-icon.png - BYTE Power
Fc9-comp-macro.png Initialise
Starts up the formula flowcode PWM for motor control and performs the wait for button press
LEDOff
Fc9-comp-macro.png LEDOff
Switches off a single LED on the front of the Formula Flowcode.
Fc9-u8-icon.png - BYTE LED
LEDOn
Fc9-comp-macro.png LEDOn
Switches on a single LED on the front of the Formula Flowcode.
PlayNote
Fc9-comp-macro.png PlayNote
Outputs a single tone from the onboard speaker for the period specified
Fc9-u8-icon.png - BYTE Note
Fc9-u16-icon.png - UINT Delay_ms
ReadIRSensor
Fc9-comp-macro.png ReadIRSensor
Reads the analogue value from the specified IR distance sensor.
ReadLDR
Fc9-comp-macro.png ReadLDR
Reads the current audio signal level from the on-board light sensor.
Fc9-s16-icon.png - INT Return
ReadLineSensor
Fc9-comp-macro.png ReadLineSensor
Returns the digital value from the line sensor specified.
ReadMic
Fc9-comp-macro.png ReadMic
Reads the current audio signal level from the on-board microphone.
ReadSwitch
Fc9-comp-macro.png ReadSwitch
Reads the value of one of the switches from the front of the Formula Flowcode.
Fc9-u8-icon.png - BYTE Switch
Reverse
Fc9-comp-macro.png Reverse
Drives both motors of the formula flowcode backwards with the power specified.
SetMotors
Fc9-comp-macro.png SetMotors
Sets the speed and direction of the Formula Flowcode motors.
Fc9-s16-icon.png - INT Left_Power
Valid Range = -255 to 255
Fc9-s16-icon.png - INT Right_Power
SpinLeft
Fc9-comp-macro.png SpinLeft
Spins the formula flowcode on the spot in an anticlockwise direction as seen from above.
SpinRight
Fc9-comp-macro.png SpinRight
Spins the formula flowcode on the spot in a clockwise direction as seen from above.
Stop
Fc9-comp-macro.png Stop
Stops both motors
WaitForSwitch
Fc9-comp-macro.png WaitForSwitch
Waits for the specified switch to be pressed.
WriteLEDs
Fc9-comp-macro.png WriteLEDs
Allows control of all 8-LEDs on the front of the Formula Flowcode.
Fc9-u8-icon.png - BYTE LED_Byte
Fc9-type-7-icon.png Wait For Button
Determines if the program will automatically wait for one of the front switches to be pressed before executing the program.
Fc9-type-16-icon.png IR Sensitivity
InfraRed read mode - 8-bit or 10-bit
Fc9-type-14-icon.png Motor Balance (-100 - 100)
Motor balance, way of modifying the relative speeds of the motors to allow mismatched motors to work together better.
Fc9-conn-icon.png IR Thresholds (CheckIR macro)
Fc9-type-14-icon.png Left
IR Threshold used with the CheckIR macro
Fc9-type-14-icon.png Front
Fc9-type-14-icon.png Right
Fc9-conn-icon.png Simulation Parameters
Fc9-type-14-icon.png Sim Speed (1 - 100)
Sets the simulated amount of movement relative to the speed of the formula flowcode
Fc9-type-7-icon.png Smooth Animation
Selects if the simulation has additional smoothing going on in between iterations
Fc9-type-7-icon.png Manual Redraw
Sets if the animation forces it's own redraws or waits for the system to perform a redraw
Fc9-type-14-icon.png Timer Interval (ms)
Interval in ms between each iteration of the formula flowcode simulated movement
Fc9-type-14-icon.png IR Sensor Iterations
Number of times to repeat the IR sensor tests and therefore how far the simulated IR sensors can sense.
Fc9-type-15-icon.png IR Sensor Resolution
The amount of distance to travel for each iteration of the IR sensor
Fc9-type-16-icon.png Collision Method
Sets whether the sensors on the formula flowcode interact with everything on the panel or just a specific group.
