Component: Airplane Landing Gear (Scenarios)
(Redirected from Component: ID a05022fd 6fa1 499d b885 a7d983e7bfdf)
Version | 1.0 |
Category | Scenarios |
Airplane Landing Gear component
A simulation of an Airplane Landing Gear containing, switches, locking mechanisms and retracting landing gear.
Please click here to download the component source project: FC_Comp_Source_LandingGearComponent_v002.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LandingGearComponent_v002.fcfx
Airplane Landing Gear Scenario
FrontDoorCloseSwitch
FrontDoorLocks
FrontDoorLocks | |
Will lock or unlock the front doors depending on the number given to the paremeter. | |
- BYTE | OpenOrClose |
Open =1 Close=0 | |
- VOID | Return |
FrontDoorOpenSwitch
FrontDoors
FrontDoors | |
Will allow the front doors to open. | |
- BYTE | Direction |
Drops the door down or close them. 0 = Close 1 = Open | |
- VOID | Return |
LandingGear
LandingGear | |
Retracts and drops the landing gear. | |
Drop the wheel down or retracts them. 0 = Retracts 1 = Drop | |
- VOID | Return |
LandingGearDownSwitch
LandingGearUpSwitch
LandingGearUpSwitch | |
Test to see if the Landing Gear will touch the collision switch above it. If it does, will return true. and stop movement. Assigned variable of a Bool is recommended | |
- BYTE | Return |
RearDoorCloseSwitch
RearDoorCloseSwitch | |
Test to see if the rear door will touch the collision switch by its original position. If it does, will return true. and stop movement. | |
- BYTE | Return |
RearDoorLocks
RearDoorLocks | |
Will unlock or lock the rear doors | |
Open =1 Close =0 | |
- VOID | Return |
RearDoorOpenSwitch
RearDoorOpenSwitch | |
Test to see if the rear door will touch the collision switch by its final position. If it does, will return true. and stop movement. | |
- BYTE | Return |
RearDoors
RearDoors | |
Will allow the rear door to open | |
Drop the door down or close them. 0 = Close 1 = Open | |
- VOID | Return |
Properties |
