Component: Bluetooth (HC05 / HC06) (Wireless)
Version 2.1
Category Wireless
Bluetooth (HC05 / HC06) component
Low level routines for controlling or interacting with a HC05 or HC06 Bluetooth module. Contains functions to allow the baud rate, bluetooth name and bluetooth key to be defined.
Please click here to download the component source project: FC_Comp_Source_BTHC05.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_BTHC05.fcfx
Example Program that configures a HC05 / HC06 Bluetooth module and then allows a data connection to be established and utilised.
Incoming data will be displayed on an LCD.
Outgoing data is assigned and sent using a keypad component. FC6 Icon.png HC05 Example
Fc9-comp-macro.png Initialise
Sets up the RS232 peripheral, must be called at the start of your program or at least before you start calling any other RS232 macros.
ReceiveChar
Fc9-comp-macro.png ReceiveChar
Attempts to receive a single packet from the UART interface.
Fc9-s16-icon.png - INT Timeout
Time to wait for valid data before returning, 0=Dont wait, 255=Wait forever.
Fc9-s16-icon.png - INT Return
ReceiveString
Fc9-comp-macro.png ReceiveString
Attempts to receive a string of bytes from the UART interface.
Fc9-u8-icon.png - BYTE Timeout
Fc9-u8-icon.png - BYTE NumBytes
SendChar
Fc9-comp-macro.png SendChar
Sends out a single packet from the UART interface.
Fc9-s16-icon.png - INT Char
SendCommand
Fc9-comp-macro.png SendCommand
Sends a command string to the HC05/HC06 module.
Fc9-string-icon.png - STRING Command
SendNumber
Fc9-comp-macro.png SendNumber
Sends out a number as an ASCII String from the UART interface.
[[File:]] - Number
SendString
Fc9-comp-macro.png SendString
Sends out a string of bytes from the UART interface.
SetBaud
Fc9-comp-macro.png SetBaud
Sets the Bluetooth baud rate stored in the Bluetooth module's ROM. Commands must be sent before Bluetooth communications are estabished e.g. right after power on and initialisation.
Fc9-u8-icon.png - BYTE Baud
1=1200, 2=2400, 3=4800, 4=9600, 5=19200, 6=NA, 7=38400, 8=57600, 9=115200
SetName
Fc9-comp-macro.png SetName
Sets the Bluetooth Friendly name stored in the Bluetooth module's ROM. Commands must be sent before Bluetooth communications are estabished e.g. right after power on and initialisation.
Fc9-string-icon.png - STRING Name
Name you wish to provide to the module
SetPairKey
Fc9-comp-macro.png SetPairKey
Sets the Bluetooth pair key stored in the Bluetooth module's ROM. Commands must be sent before Bluetooth communications are estabished e.g. right after power on and initialisation.
Fc9-string-icon.png - STRING Key
Four digit pair key e.g. "0000" or "1234"
Fc9-conn-icon.png Comms Settings
Fc9-type-16-icon.png Data Bits
Number of data bits
Fc9-type-16-icon.png Return
Return data width from Receive macro. 8-bit data mode always returns a byte ranging from 0-255, 255 could mean a timeout or could be a valid data. 16-bit data mode rereturns 0-255 for valid data, 256 for a timeout, return data must be stored into an INT or UINT variable.
Fc9-type-16-icon.png Echo
Echo selection
Fc9-type-16-icon.png Baud Options
Fc9-type-16-icon.png Channel
Fc9-type-7-icon.png Use TX
Selects if the Transmit pin is used by the component. Yes: The TX pin is active and used to transmit data for the UART. No: The TX pin is disabled and free to be used as general I/O.
Fc9-type-5-icon.png TX
Fc9-type-7-icon.png Use RX
Selects if the Receive pin is used by the component. Yes: The RX pin is active and used to receive data for the UART. No: The RX pin is disabled and free to be used as general I/O.
Fc9-type-5-icon.png RX
Fc9-type-16-icon.png Use Flow Control
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
Textual label shown on the component I/O flasher
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port API - Routes the communication data via a data injector component on the Panel.
