Component: Current Sensor (ACS7xx) (Electrical)
Author medelec35
Category Electrical
Current Sensor (ACS7xx) component
ACS7XX range of unidirectional and bidirectional 5, 20, 30, 50, 100, 150 & 200A current sensors
Please click here to download the component source project: FC_Comp_Source_Current_Sensor_ACS7xx.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Current_Sensor_ACS7xx.fcfx
A simple example shows how to use a ASC712 to measure current range of +/- 5A. The component type can be changed within its properties.
FC6 Icon.png ACS712 example
Current
Fc9-comp-macro.png Current
Current reading in amps
VoltgeADC
Fc9-comp-macro.png VoltgeADC
Reads the Voltage of the ADC pin for diagnostic purposes. With no current flowing through the sensor, the voltage reading should be 2.50V. If that is out, then enter precise VDD within properties
Fc9-type-16-icon.png Device
Fc9-type-16-icon.png Type
Fc9-type-15-icon.png VDD
Fc9-type-15-icon.png Offset current adjust (Amps)
Offset current adjusts the curent output when comparing to a current monitor. For example current from the componet shows 2.0 Amps and curent monitor shows 1.5 Amps. For the current offset enter -0.5
Fc9-type-6-icon.png Channel
