Component: Circular Buffer (8-bit) (Buffer)
Version 1.5
Category Buffer
Circular Buffer (8-bit) component
Circular buffer component allowing easy and efficient first in first out (FIFO) style data byte storage. Useful when used with a comms component to capture data as it comes in ready for processing when we have time. Also features macros to allow you to check for specific incoming responses such as "OK" or "ERROR".
Please click here to download the component source project: FC_Comp_Source_CircularBuffer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_CircularBuffer.fcfx
Basic Example
Circular Buffer Example File demonstrating the storage and retrieval of data. FC6 Icon.png CircularBuffer System panel showing data in and data out of the FIFO circular buffer.
Console window showing data in the circular buffer on the first simulation run.
Console window showing data in the circular buffer on the second simulation run, note that the start location has been shifted and will eventually wrap hence the name, circular buffer.
Keypad Based Door Entry System
Each key press on the keypad is fed into the Circular Buffer component. We then poll the buffer to see if the correct characters for the password have been entered. FC6 Icon.png Keypad Door Entry If the correct sequence is detected then we activate the solenoid component for 5 seconds.
Reliable Communications Data
This example takes bytes received from the Serial UART and uses the circular buffer to store the bytes as they come in using an interrupt. The main routine then forwards the bytes through to a PC using a USB serial connection. This example would work equally well for creating a bridge between several UARTs or translating Serial to SPI or I2C etc. FC6 Icon.png UART to USB Serial Data Bridge
AT Command Responses
This example sends out AT commands to an AT based communications module e.g. GSM or Bluetooth. The response from the module is stored in the circular buffer and we then scan the buffer for appropriate responses from the module. The outcome of the command is then printed to the LCD to let you know if the command was accepted, caused an error or simply timed out. FC6 Icon.png Reliable AT Command Response
Searching for none ASCII characters
The LookForValue and WaitForValue functions can be useful when searching for ASCII data in the circular buffer. You can also use the escape sequence \x to search for hexadecimal values in the buffer.
e.g. "ABC\xFF\x80"
Will look for the ASCII characters A,B,C followed by the byte values 255 (0xFF) and 128 (0x80).
FlushBuffer
Fc9-comp-macro.png FlushBuffer
Clears the contents of the buffer and re-initialises the index locations.
GetArray
Fc9-comp-macro.png GetArray
Reads an array of Bytes from the circular buffer.
Fc9-u8-icon.png - BYTE Data
Data array to store the data into
Fc9-u16-icon.png - UINT NumBytes
Number of bytes to read from the buffer
GetByte
Fc9-comp-macro.png GetByte
Reads the next available byte from the circular buffer, Returns 255 if the buffer is empty.
GetConsoleHandle
GetIndexedByte
Fc9-comp-macro.png GetIndexedByte
Gets the value of a single byte at a known location in the buffer. Leaves the buffer contents and pointers untouched.
Fc9-u16-icon.png - UINT address
GetNumberBytes
Fc9-comp-macro.png GetNumberBytes
Returns the number of valid data bytes currently inside the buffer.
GetString
Fc9-comp-macro.png GetString
Reads a string of characters from the circular buffer.
Fc9-u16-icon.png - UINT MaxLength
Max number of bytes the string can store including the null byte
LookForValue
Fc9-comp-macro.png LookForValue
Scans the buffer for an array of specific values. Returns 0 if the value is not found. Returns 1 if the value is found.
Fc9-string-icon.png - STRING Value
Value to look for, can be a string or byte array,
Fc9-u8-icon.png - BYTE NumChars
The number of characters you wish to try and match
Fc9-u8-icon.png - BYTE RemoveContent
0=Leave data alone, 1=Remove data from buffer
Fc9-u8-icon.png - BYTE ResetFind
0=Continue the find from the last operation, 1=Start again
PeekByte
Fc9-comp-macro.png PeekByte
Reads the next available byte from the circular buffer without advancing the current index, Returns 255/512 if the buffer is empty.
PutArray
Fc9-comp-macro.png PutArray
Writes an array of bytes into the circular buffer.
Byte array to write into the buffer
Number of bytes to write into the buffer
PutByte
Fc9-comp-macro.png PutByte
Add byte to the next free location inside the circular buffer. If the data goes into the buffer correctly then return 1. Otherwise the buffer is full and the return value will equal 0.
PutString
Fc9-comp-macro.png PutString
Writes a string of characters into the circular buffer.
String data array to write into the buffer
WaitForValue
Fc9-comp-macro.png WaitForValue
Waits for an array of values to appear in the circular buffer. Returns 0 to indicate a timeout. Returns 1 to indicate the data has been found.
Number of characters to try and look for
0=Leave the buffer contents untouched, 1=Remove values as you go
Fc9-u16-icon.png - UINT Timeout
Max amount of time to wait in milliseconds before returning 0=WaitForever
Sets the number of byte elements inside the circular buffer.
Fc9-type-16-icon.png Storage Type
When buffer is full this property decides what to do. Store first x values - Will retain the information inside the buffer, new data will be discarded. Store last x values - Will discard the oldest location in the buffer and overwrite with new data.
Fc9-type-16-icon.png Memory Type
Fc9-type-16-icon.png Return Type
Specifies the way the receive function indicates a timeout. 8 Bit mode - Timeout is represented by the value 255. 16 Bit mode - Timeout is represented by the value 512 allowing the value 255 to represent valid data
Fc9-type-7-icon.png Console
Decides if the contents of the buffer are shown in a console tab.
