Component: LED (5mm, PCB) ()
Author | Matrix Ltd |
Version | 1.1 |
Category |
LED (5mm, PCB) component
An industry standard 5mm diameter LED. Any color may be chosen, and the leads trimmed to length.
Please click here to download the component source project: FC_Comp_Source_led_5mm_basic.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_led_5mm_basic.fcfx
