Component: Car Seat (Scenarios)
(Redirected from Component: ID fde30de0 35ed 40ca 937a 88da6409c1d2)
Version | 1.0 |
Category | Scenarios |
Car Seat component
An electric car seat chassis with a series of motors and sensors. Students should work through exercises to learn the principles of electric car seats including how to save and load memory positions.
Please click here to download the component source project: FC_Comp_Source_CarSeatSource_v004.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_CarSeatSource_v004.fcfx
CurrentSenseMotor1
CurrentSenseMotor2
CurrentSenseMotor3
Encoder1
Encoder1 | |
Returns value is equal to X Axis current value (forward/ backwards movement). | |
- INT | Return |
Encoder2
Encoder2 | |
Returns value is equal to Front Z Axis current value. | |
- INT | Return |
Encoder3
Encoder3 | |
Returns value is equal to Rear Z Axis current value. | |
- INT | Return |
Load
Load | |
Moves the seat back into the last saved position stored in the allocated save slot. | |
- BYTE | Location |
0 = A, 1 = B | |
- VOID | Return |
Motor1
Motor1 | |
Moves the Car Seat Forwards and Backwards | |
- BYTE | Direction |
0 = Stop, 1 = Forward, 2 = Backward | |
- VOID | Return |
Motor2
Motor2 | |
Controls the Movement of the seat going up and down by the front | |
0 = Stop, 1 = Up, 2 = Down | |
- VOID | Return |
Motor3
Motor3 | |
Controls the Movement of the seat going up and down by the back | |
- VOID | Return |
Save
Save | |
Saves the current position of the seat into the allocated save slot. | |
- BYTE | SavePos |
0 = pos A, 1 = pos B | |
- VOID | Return |
Properties | |
Show seat base? | |
Controls if the base of the car seat is shown on the simulation panel. |
