MediaWiki API help
This is an auto-generated MediaWiki Action API documentation page.
action=block
- This module requires read rights.
- This module requires write rights.
- This module only accepts POST requests.
- Source: MediaWiki
- License: GPL-2.0-or-later
Block a user.
- id
ID of the block to modify (obtained through list=blocks). Cannot be used together with user, reblock, or newblock.
- Type: integer
- user
User to block. Cannot be used together with id.
- Type: user, by any of username, IP, Temporary user, IP range and user ID (e.g. "#12345")
- userid
- Deprecated.
Specify user=#ID instead.
- Type: integer
- expiry
Expiry time. May be relative (e.g. 5 months or 2 weeks) or absolute (e.g. 2014-09-18T12:34:56Z). If set to infinite, indefinite, or never, the block will never expire.
- Default: never
- reason
Reason for block.
- Default: (empty)
- anononly
Block anonymous users only (i.e. disable anonymous edits for this IP address, including temporary account edits).
- Type: boolean (details)
- nocreate
Prevent account creation.
- autoblock
Automatically block the last used IP address, and any subsequent IP addresses they try to login from.
- noemail
Prevent user from sending email through the wiki. (Requires the
blockemailright).- Type: boolean (details)
- hidename
Hide the username from the block log. (Requires the
hideuserright).- Type: boolean (details)
- allowusertalk
Allow the user to edit their own talk page (depends on $wgBlockAllowsUTEdit).
- reblock
If the user is already blocked by a single block, overwrite the existing block. If the user is blocked more than once, this will fail—use the id parameter instead to specify which block to overwrite. Cannot be used together with id or newblock.
- newblock
Add another block even if the user is already blocked. Cannot be used together with id or reblock.
- watchuser
Watch the user's or IP address's user and talk pages.
Change tags to apply to the entry in the block log.
- Values (separate with | or alternative): Flowcode v8, Flowcode v9, Flowcode v10, Version
- partial
Block user from specific pages or namespaces rather than the entire site.
- pagerestrictions
List of titles to block the user from editing. Only applies when partial is set to true.
- Type: page title
- Separate values with | or alternative.
- Maximum number of values is 10.
- Only accepts pages that exist.
- namespacerestrictions
List of namespace IDs to block the user from editing. Only applies when partial is set to true.
- Values (separate with | or alternative): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15
- To specify all values, use *.
- actionrestrictions
List of actions to block the user from performing. Only applies when partial is set to true.
- Values (separate with | or alternative): create, move, upload
- token
A "csrf" token retrieved from action=query&meta=tokens
- This parameter is required.
- Block IP address 192.0.2.5 for three days with a reason.
- api.php?action=block&user=192.0.2.5&expiry=3%20days&reason=First%20strike&token=123ABC [open in sandbox]
- Block user Vandal indefinitely with a reason, and prevent new account creation and email sending.
- api.php?action=block&user=Vandal&expiry=never&reason=Vandalism&nocreate=&autoblock=&noemail=&token=123ABC [open in sandbox]
