MediaWiki API help
This is an auto-generated MediaWiki Action API documentation page.
action=move
(main | move)
  • This module requires read rights.
  • This module requires write rights.
  • This module only accepts POST requests.
  • Source: MediaWiki
  • License: GPL-2.0-or-later
Move a page.
Specific parameters:
Other general parameters are available.
from
Title of the page to rename. Cannot be used together with fromid.
fromid
Page ID of the page to rename. Cannot be used together with from.
Type: integer
to
Title to rename the page to.
This parameter is required.
reason
Reason for the rename.
Default: (empty)
movetalk
Rename the talk page, if it exists.
Type: boolean (details)
movesubpages
Rename subpages, if applicable.
noredirect
Don't create a redirect.
watchlist
Unconditionally add or remove the page from the current user's watchlist, use preferences (ignored for bot users) or do not change watch.
One of the following values: nochange, preferences, unwatch, watch
Default: preferences
ignorewarnings
Ignore any warnings.
tags
Change tags to apply to the entry in the move log and to the dummy revision on the destination page.
Values (separate with | or alternative): Flowcode v8, Flowcode v9, Flowcode v10, Version
token
A "csrf" token retrieved from action=query&meta=tokens
