MediaWiki API help
This is an auto-generated MediaWiki Action API documentation page.
action=protect
(main | protect)
  • This module requires read rights.
  • This module requires write rights.
  • This module only accepts POST requests.
  • Source: MediaWiki
  • License: GPL-2.0-or-later
Change the protection level of a page.
Specific parameters:
Other general parameters are available.
title
Title of the page to (un)protect. Cannot be used together with pageid.
pageid
ID of the page to (un)protect. Cannot be used together with title.
Type: integer
protections
List of protection levels, formatted action=level (e.g. edit=sysop). A level of all means everyone is allowed to take the action, i.e. no restriction.
Note: Any actions not listed will have restrictions removed.
This parameter is required.
Separate values with | or alternative.
Maximum number of values is 50 (500 for clients that are allowed higher limits).
expiry
Expiry timestamps. If only one timestamp is set, it'll be used for all protections. Use infinite, indefinite, infinity, or never, for a never-expiring protection.
Default: infinite
reason
Reason for (un)protecting.
Default: (empty)
tags
Change tags to apply to the entry in the protection log.
Values (separate with | or alternative): Flowcode v8, Flowcode v9, Flowcode v10, Version
cascade
Enable cascading protection (i.e. protect transcluded templates and images used in this page). Ignored if none of the given protection levels support cascading.
Type: boolean (details)
watch
Deprecated.
If set, add the page being (un)protected to the current user's watchlist.
watchlist
Unconditionally add or remove the page from the current user's watchlist, use preferences (ignored for bot users) or do not change watch.
One of the following values: nochange, preferences, unwatch, watch
Default: preferences
token
A "csrf" token retrieved from action=query&meta=tokens
