MediaWiki API help
This is an auto-generated MediaWiki Action API documentation page.
action=unblock
(main | unblock)
  • This module requires read rights.
  • This module requires write rights.
  • This module only accepts POST requests.
  • Source: MediaWiki
  • License: GPL-2.0-or-later
Unblock a user.
Specific parameters:
Other general parameters are available.
id
ID of the block to unblock (obtained through list=blocks). Cannot be used together with user.
Type: integer
user
User to unblock. Cannot be used together with id.
Type: user, by any of username, IP, Temporary user, IP range and user ID (e.g. "#12345")
userid
Deprecated.
Specify user=#ID instead.
Type: integer
reason
Reason for unblock.
Default: (empty)
tags
Change tags to apply to the entry in the block log.
Values (separate with | or alternative): Flowcode v8, Flowcode v9, Flowcode v10, Version
watchuser
Watch the user's or IP address's user and talk pages.
Type: boolean (details)
token
A "csrf" token retrieved from action=query&meta=tokens
This parameter is required.
