Component: Injector (AT) (Simulation)
Author | Matrix Ltd |
Version | 1.0 |
Category | Simulation |
This inherits from Data Injector |
Image Injector (AT) component
Comms data injector to replicate basic AT command syntax. The component will record each incoming character until the termination character is received. Once this happens the component will respond by echoing back the received data followed by an "OK" reply.
This component does not contain any downloadable macros
Simulation macro reference
This component inherits simulation macros from Data Injector
TxByte
- BYTE DataByte
RxByte
Gets a byte from the comms channel - 255 signifies no more data available
GetTxConsoleHandle
This call is provided by Data Injector
ChangeState
Changes the state for I2C or SPI type comms where the data bytes along are not enough to go on.
- BYTE NewState
- Assigns new state, 0=default
GetRxConsoleHandle
InitialiseInjector
- <- STRING InjectorName
- Name of the console that will be created
GetConsoleHandle
Circular Buffer Size
This property is of type Unsigned integer and can be referenced with the variable name CircularBufferSize.
Amount of room in the circular buffers before running out of memory.
e.g. max command that can be recorded.
Termination Character
This property is of type Fixed list of ints and can be referenced with the variable name TermChar.
Character that will trigger the AT Injector to automatically switch from recording to repeating.
