Component: Switch Array Base (Inputs: General)
Revision as of 11:25, 13 February 2015 by MartinB (talk | contribs) (XML import)
Author Matrix Ltd.
Version 1.4 (Release)
Category Inputs: General
Image Switch Array Base component
A base component for creating an evenly spaced array of switches. Each will be connected to sequential pins of a given I/O port. Set target object to point at any standard switch component to change the type of switch used by the array.
This component can be used as a base to create child components
The following components all inherit the traits of Switch Array Base:
Image Switch Array (Push) An array of up to eight momentary push switches, each connected to a single pin of the specified port.
Image Switch Array (Slide) An array of up to eight slide switches, each connected to a single pin of the specified port.
ReadState
Read the state of the switch at the given index.
BYTE Index
The switch to read the status of.
BOOL : Key state - true = on, false = off
WaitUntilHigh
Pause the program until the switch at the given index is turned on.
BYTE Index
Index of the switch to wait for.
ReadAll
Reads all of the switches at once, returning a byte containing one bit per
switch.
This macro has no parameters
BYTE : One bit per switch in the array.
WaitUntilLow
BYTE Index
Simulation macro reference
GetHandle
Retrieves the object handle of the switch component at the given index.
BYTE Index
HANDLE
Count
This property is of type Unsigned integer and can be referenced with the variable name count.
The number of LEDs in the array from 1 to 8.
Port
This property is of type Fixed list of ints and can be referenced with the variable name port.
Choose a single port for all LEDs - pins are allocated in sequence from pin 0 -
...or choose 'Custom pins' to assign each switch individually.
Switch 0
This property is of type Single digital pin and can be referenced with the variable name pin0.
Chip pin connection for LED 0
Switch 1
This property is of type Single digital pin and can be referenced with the variable name pin1.
Chip pin connection for LED 1
Switch 2
This property is of type Single digital pin and can be referenced with the variable name pin2.
Chip pin connection for LED 2
Switch 3
This property is of type Single digital pin and can be referenced with the variable name pin3.
Chip pin connection for LED 3
Switch 4
This property is of type Single digital pin and can be referenced with the variable name pin4.
Chip pin connection for LED 4
Polarity
This property is of type Fixed list of ints and can be referenced with the variable name polarity.
Active High = LEDs light when the chosen chip pin is ON
Active Low = LEDs light when the chosen chip pin is OFF
Debounce
This property is of type Signed integer and can be referenced with the variable name debounce.
Time in milliseconds allowed for the pin to settle following a change of state.
Operation
This property is of type Fixed list of ints and can be referenced with the variable name operation.
Sets whether switches toggle or are press/release.
NB) This option can only be set when the original target includes this option.
Alignment
This property is of type Fixed list of ints and can be referenced with the variable name align.
Which 3D axis to align the copies along.
Spacing
This property is of type Floating point and can be referenced with the variable name spacing.
The distance between LEDs in the array.
LEDs will be spaced symmetrically around the component centre.
Use a negative value to reverse the order of the LEDs.
Reverse
This property is of type True or false and can be referenced with the variable name reverse.
Whether to reverse the order of the switches.
Show Labels
This property is of type Fixed list of ints and can be referenced with the variable name show_labels.
Whether to show labels giving each switch's pin connection.
Label color
This property is of type Color picker and can be referenced with the variable name label_color.
Color of the port and pin labels
Target Switch
This property is of type Panel object and can be referenced with the variable name target_object.
To use a custom switch design...
- Drag any switch component onto the panel, or create your own using the 'Switch base'
- Give your new switch a memorable name.
- Choose the new switch in this property; copies will be made to fill the array, and the original is hidden.
When unconnected, it will use a default 'basic switch'.
