Component: GLCD (SSD1322) Buffered (Outputs: General)
Revision as of 12:13, 21 July 2016 by BenR (talk | contribs) (XML import)
Version 1.6 (Release)
Category Outputs: General
This inherits from GLCD base
Image GLCD (SSD1322) Buffered component
Graphical display component based on the SSD1322 monochrome graphical controller IC. Functions without the use of a read pin by hosting the 2K of graphical memory using the microcontroller's RAM memory.
This component inherits downloadable macros from GLCD base
ReadASCIILUT
Gets a byte of the embedded ASCII font data.
This call is provided by GLCD base
BYTE pos_str
ASCII position -32 so A = 'A' - 32 = 33
BYTE count
Font column Ranging 0-4
BYTE
INT Number
UINT X
UINT Y
BYTE Font
Size of the font - 0 = Normal, 1 = Double Width, 2 = Double Width and Height, 3 = Double Height
BYTE Transparent
DrawLine
UINT X1
UINT Y1
UINT X2
UINT Y2
Plot
UINT X1
UINT Y1
SetDisplayOrientation
BYTE Orientation
BPlot
UINT X1
UINT Y1
Print
<- STRING Str
This parameter may be returned back to the caller
UINT X1
UINT Y1
BYTE Font
BYTE Transparent
ClearDisplay
This macro has no parameters
SetBackgroundColour
BYTE PixelColour
0=White, 1=Black
SetForegroundColour
BYTE PixelColour
0=White, 1=Black
DrawRectangle
UINT X1
UINT Y1
UINT X2
UINT Y2
BYTE Transparent
BYTE Solid
Simulation macro reference
This component inherits simulation macros from GLCD base
INT Number
UINT X
UINT Y
BYTE Font
BYTE Transparent
DrawLine
UINT X1
UINT Y1
UINT X2
UINT Y2
Plot
UINT X1
UINT Y1
BYTE Orientation
BPlot
UINT X1
UINT Y1
Print
<- STRING Str
UINT X1
UINT Y1
BYTE Font
BYTE Transparent
ClearDisplay
SetBackgroundColour
BYTE Red
BYTE Green
BYTE Blue
SetForegroundColour
BYTE Red
BYTE Green
BYTE Blue
DrawRectangle
Draws a rectangle with the current foreground colour from pixel loaction X1, Y1 to pixel location X2, Y2.
UINT X1
UINT Y1
UINT X2
UINT Y2
BYTE Transparent
BYTE Solid
Pixel Height
This property is of type Signed integer and can be referenced with the variable name pixel_height.
Pixel Width
This property is of type Signed integer and can be referenced with the variable name pixel_width.
Monochrome
This property is of type True or false and can be referenced with the variable name monochrome.
Foreground Color
This property is of type Color picker and can be referenced with the variable name foreground_colour.
Background Color
This property is of type Color picker and can be referenced with the variable name background_colour.
Colour Bit Depth
This property is of type Signed integer and can be referenced with the variable name colour_bit_depth.
Red Bit Depth
This property is of type Signed integer and can be referenced with the variable name red_bit_depth.
Green Bit Depth
This property is of type Signed integer and can be referenced with the variable name green_bit_depth.
Blue Bit Depth
This property is of type Signed integer and can be referenced with the variable name blue_bit_depth.
Chip Select (CS)
This property is of type Single digital pin and can be referenced with the variable name CS_pin.
Chip select output control pin
Data (SD)
This property is of type Single digital pin and can be referenced with the variable name SD_pin.
Serial data output control pin
Serial Clock (SCK)
This property is of type Single digital pin and can be referenced with the variable name SCK_pin.
Serial clock output control pin
Reset (RST)
This property is of type Single digital pin and can be referenced with the variable name Reset_pin.
Reset control pin
Display Method
This property is of type Fixed list of ints and can be referenced with the variable name DisplayMethod.
Chooses which method to use when drawing to the gLCD component
The bitmap is the more common mode but may run slowly on some machines.
The point cloud should run faster but may use more memory.
