Component: 7Segment (Quad) (Outputs: General)
Revision as of 12:13, 21 July 2016 by BenR (talk | contribs) (XML import)
Version 1.2 (Release)
Category Outputs: General
Image 7Segment (Quad) component
14mm seven segment display. LED colour can be set from properties.
Basic Multiplexing
Only one of the four 7-segment LEDs can be enabled at a time so we need a way of multiplexing the output so that we can display a number on all four LEDs. To do this we switch between LED outputs at fairly high speed and persistence of vision allows the display to appear fixed and constant.
This example demonstrates a very basic loop to display a four digit number multiplexed across four 7segment displays. FC6 Icon.png Quad 7Segment Display Example
Timer Based Multiplexing
This example demonstrates a timer interrupt to display a four digit number multiplexed across four 7segment displays. The timer interrupt takes care of updating the display leaving our program free to count up in 100ms increments. FC6 Icon.png Quad 7Segment Display Example 2 The panel should show the simulation run time down to the current tenth of a second.
ShowDigit
Set the number and decimal point to be displayed in the given digit of the display.
BYTE Digit
Which of the four digits to change. (0...3)
BYTE Value
The number value to set the digit to (0...15), 16=Clear
BYTE DecimalPoint
Whether to show the decimal point for the chosen digit.
Simulation macro reference
Display Type
This property is of type Fixed list of ints and can be referenced with the variable name Display_Type.
Set this according to the specification of your hardware display.
Common Anode: Pin true -> LED Off, Pin false -> LED On
Common Cathode: Pin true -> LED On, Pin false -> LED Off
Show Seg Labels
This property is of type True or false and can be referenced with the variable name ShowSegLabels.
Show segment name labels overlayed over the component.
Common Pin 0
This property is of type Single digital pin and can be referenced with the variable name Common_Pin0.
Pin to enable the first digit.
Common Pin 1
This property is of type Single digital pin and can be referenced with the variable name Common_Pin1.
Pin to enable the second digit.
Common Pin 2
This property is of type Single digital pin and can be referenced with the variable name Common_Pin2.
Pin to enable the third digit.
Common Pin 3
This property is of type Single digital pin and can be referenced with the variable name Common_Pin3.
Pin to enable the fourth digit.
Pin0 (A)
This property is of type Single digital pin and can be referenced with the variable name Pin0.
Pin for the 'A' segments of the displays.
Pin1 (B)
This property is of type Single digital pin and can be referenced with the variable name Pin1.
Pin for the 'B' segments of the displays.
Pin2 (C)
This property is of type Single digital pin and can be referenced with the variable name Pin2.
Pin for the 'C' segments of the displays.
Pin3 (D)
This property is of type Single digital pin and can be referenced with the variable name Pin3.
Pin for the 'D' segments of the displays.
Pin4 (E)
This property is of type Single digital pin and can be referenced with the variable name Pin4.
Pin for the 'E' segments of the displays.
Pin5 (F)
This property is of type Single digital pin and can be referenced with the variable name Pin5.
Pin for the 'F' segments of the displays.
Pin6 (G)
This property is of type Single digital pin and can be referenced with the variable name Pin6.
Pin for the 'G' segments of the displays.
Pin7 (DP)
This property is of type Single digital pin and can be referenced with the variable name Pin7.
Pin for the decimal points of the displays.
LED Color
This property is of type Color picker and can be referenced with the variable name FGColor.
Color of the LED segments when truned on. When off, they use a much darker shade of the same hue.
Body Color
This property is of type Color picker and can be referenced with the variable name BGColor.
Color of the plastic casing containing the LEDs.
Label Color
This property is of type Color picker and can be referenced with the variable name LabelColor.
Color for the optional LED segment labels.
