Component: RFID2 (Wireless)
Revision as of 12:13, 21 July 2016 by BenR (talk | contribs) (XML import)
Author Ben Rowland and STibor
Version 2.0 (Release)
Category Wireless
Image RFID2 component
Functions designed to work with the MFRC522 contactless reader IC. The MFRC522 supports all variants of the MIFARE Mini, MIFARE 1K, MIFARE 4K, MIFARE Ultralight, MIFARE DESFire EV1 and MIFARE Plus RF identification protocols.
WriteBlock
Writes the contents of the 16-byte data buffer to the RFID block.
The data comes from the DataBuffer which can be set using the
WriteDataBuffer macro.
Returns 0 for a succesful write.
BYTE BlockAddress
BYTE
ReadDataBuffer
Reads a byte from the receive data buffer.
ID locations are 0-4
Data locations are 0-15
BYTE Index
Locations 0-15
BYTE
AntennaOff
Switches off the RFID antenna
This macro has no parameters
ReadBlock
Reads the contents of the 16-byte data buffer block on the RFID.
The receive data is stored in the data buffer and read back using the ReadDataBuffer macro.
Returns 0 for a succesful read.
BYTE BlockAddress
BYTE
SelectTag
BYTE Ser0
BYTE Ser1
BYTE Ser2
BYTE Ser3
BYTE Ser4
BYTE
WriteDataBuffer
Writes a value to the 16-byte data buffer
BYTE Index
0-15
BYTE Data
Auth
BYTE AuthMode
BYTE BlockAddress
BYTE Key0
BYTE Key1
BYTE Key2
BYTE Key3
BYTE Key4
BYTE Key5
BYTE Ser0
BYTE Ser1
BYTE Ser2
BYTE Ser3
BYTE
AntennaOn
Switches on the RFID antenna
Compare
Compares the read address from the Check macro with a fixed 5 bytes address.
Returns 0 if the addresses match.
BYTE Add0
BYTE Add1
BYTE Add2
BYTE Add3
BYTE Add4
BYTE
Initialises the RFID module ready for interaction with RFID tags.
Check
BYTE
Simulation macro reference
This property is of type Fixed list of ints and can be referenced with the variable name CHANNEL.
MISO / SDI
This property is of type Single digital pin and can be referenced with the variable name MISO.
SPI Data In Pin
MOSI / SDO
This property is of type Single digital pin and can be referenced with the variable name MOSI.
SPI Data Out Pin
SCK
This property is of type Single digital pin and can be referenced with the variable name CLK.
SPI Serial Clock Pin
SS
This property is of type Single digital pin and can be referenced with the variable name CS.
SPI Chip Select Pin
Reset
This property is of type Single digital pin and can be referenced with the variable name reset.
MFRC522 Reset Pin
