Component: CAN (Peripheral CAL)
Revision as of 15:45, 20 July 2016 by BenR (talk | contribs) (XML import)
Version 1.0 (Release)
Category Peripheral CAL
Image CAN component
Low level routines for controling the CAN interface
SetTxIdentStd
Sets the ID to send along with the data in the next CAN message
BYTE Buffer
Send buffer: 0 to,2
BYTE Hi
The high byte (bits 8-15) of the ID
BYTE Lo
The low byte (bits 0-7) of the ID
SetTxIdentExd
Sets the optional 32-bit ID to send along with the standard ID and data in the next CAN message
BYTE Buffer
Send buffer: 0 to,2
BYTE ID3
The high byte (bits 24-31) of the ID
BYTE ID2
The mid-high byte (bits 16-23) of the ID
BYTE ID1
The mid-low byte (bits 8-15) of the ID
BYTE ID0
SetTxData
Sets the CAN transmit data for the buffer specified (0, 1 or 2).
The count parameter Data_Cnt indicates the number of valid data bytes.
D0 to D7 are the payload data bytes to be loaded into the transmit buffer.
BYTE Buffer
Send buffer: 0 to,2
BYTE Data_Cnt
The number of bytes of data to add, 0 to 8
BYTE D0
Data byte 0 to add
BYTE D1
Data byte 1 to add
BYTE D2
Data byte 2 to add
BYTE D3
Data byte 3 to add
BYTE D4
Data byte 4 to add
BYTE D5
Data byte 5 to add
BYTE D6
Data byte 6 to add
BYTE D7
Data byte 7 to add
SetRxMask
Generic function to set Identifier.
CAN registers will be configured depending upon Std/Ext mode setting.
BYTE mask
ULONG id
GetRxData
Returns the data byte at index from the buffer specified
BYTE buffer
The index of the required buffer
BYTE index
The index of the required data byte in the buffer
BYTE
SendBuffer
Sends the contents of the buffer previously filled with Set_TX_... calls
BYTE Buffer
Send buffer: 0 to,2
GetRxDataCount
Returns the number of valid data bytes in the buffer
BYTE buffer
BYTE
Init
Must be called at least once and after every Uninit call to enable the CAN instance
This macro has no parameters
SetRxMaskStd
Sets the 16-bit filter as a bit-mask of the standard ID for received messages
The messages are accepted if (StdID & Mask) == Filter
BYTE Mask
Mask number
BYTE Hi
BYTE Lo
SetRxMaskExd
Sets the 32-bit filter as a bit-mask of the extended ID for received messages
The messages are accepted if (ExtID & Mask) == Filter
BYTE Mask
Mask 0 or 1
BYTE ID3
BYTE ID2
BYTE ID1
BYTE ID0
SetRxFilter
BYTE filter
ULONG id
SetTxIdent
BYTE buffer
ULONG id
CheckRx
Checks to see if any messages are available for 'Buffer' specified
BYTE Buffer
Send buffer: 0 to 1
BYTE
Uninit
Uninitialises the CAN, freeing its connections for general use
GetRxIdent
Generic function to get the received message Identifier.
BYTE buffer
ULONG
SetRxFilterStd
BYTE Filter
Filter number
BYTE Hi
BYTE Lo
SetRxFilterExd
BYTE Filter
Send filter: 0 to 3
BYTE ID3
BYTE ID2
BYTE ID1
BYTE ID0
Simulation macro reference
SetBaud
GetValue
Get the Value of the Named property
STRING Name
STRING
InitRXMask
Initialization setting for RX Mask
BYTE Mask
Mask Number (0 or 1)
ULONG Value
InitRXFilter
Initialization setting for RX Filter
BYTE Filter
ULONG Value
InitTXBuffer
Initialization settings for TX Buffers
BYTE Buffer
TX Buffer ID = 0,1 or 2
ULONG ID
CAN Address
BYTE Length
Number of bytes to send
STRING Data
Data Array (of Length bytes)
SetValue
Set the Value of the Named property
<- STRING Name
This parameter may be returned back to the caller
<- STRING Value
InitRXConfig
Initialization setting for RX Buffer Config
BYTE Buffer
Buffer Number (0 or 1)
BYTE Value
Config data byte
GetList
Get the Filter List of the Named Property
STRING Name
STRING
This property is of type Fixed list of ints and can be referenced with the variable name CHANNEL.
Selects the CAN channel to be used
TX Pin
This property is of type Single digital pin and can be referenced with the variable name TXPin.
RX Pin
This property is of type Single digital pin and can be referenced with the variable name RXPin.
Bus Rate
This property is of type Fixed list of ints and can be referenced with the variable name BUS_RATE.
selects the Bus Rate (KHz)
Sample Point
This property is of type Fixed list of ints and can be referenced with the variable name SAMPLE.
selects the Sample Point for bit reading
SJW
This property is of type Fixed list of ints and can be referenced with the variable name SJW.
Synchronization Jump Width adjusts the bit
clock by 1 to 4 TQ periods
Fosc
This property is of type Signed integer and can be referenced with the variable name OSC.
BRGCON1
This property is of type Signed integer and can be referenced with the variable name BAUD1.
BRGCON2
This property is of type Signed integer and can be referenced with the variable name BAUD2.
BRGCON3
This property is of type Signed integer and can be referenced with the variable name BAUD3.
ID Type
This property is of type Fixed list of ints and can be referenced with the variable name EXID.
selects the CAN ID type
Message ID
This property is of type Signed integer and can be referenced with the variable name TXB0ID.
CAN Message ID for Transmit Buffer 0
Length
This property is of type Signed integer and can be referenced with the variable name TXB0LEN.
Number of valid data bytes in the message
D0
This property is of type Signed integer and can be referenced with the variable name TXB0DB0.
Data byte 0
D1
This property is of type Signed integer and can be referenced with the variable name TXB0DB1.
Data byte 1
D2
This property is of type Signed integer and can be referenced with the variable name TXB0DB2.
Data byte 2
D3
This property is of type Signed integer and can be referenced with the variable name TXB0DB3.
Data byte 3
D4
This property is of type Signed integer and can be referenced with the variable name TXB0DB4.
Data byte 4
D5
This property is of type Signed integer and can be referenced with the variable name TXB0DB5.
Data byte 5
D6
This property is of type Signed integer and can be referenced with the variable name TXB0DB6.
Data byte 6
D7
This property is of type Signed integer and can be referenced with the variable name TXB0DB7.
Data byte 7
Message ID
This property is of type Signed integer and can be referenced with the variable name TXB1ID.
CAN Message ID for Transmit Buffer 1
Length
This property is of type Signed integer and can be referenced with the variable name TXB1LEN.
D0
This property is of type Signed integer and can be referenced with the variable name TXB1DB0.
Data byte 0
D1
This property is of type Signed integer and can be referenced with the variable name TXB1DB1.
Data byte 1
D2
This property is of type Signed integer and can be referenced with the variable name TXB1DB2.
Data byte 2
D3
This property is of type Signed integer and can be referenced with the variable name TXB1DB3.
Data byte 3
D4
This property is of type Signed integer and can be referenced with the variable name TXB1DB4.
Data byte 4
D5
This property is of type Signed integer and can be referenced with the variable name TXB1DB5.
Data byte 5
D6
This property is of type Signed integer and can be referenced with the variable name TXB1DB6.
Data byte 6
D7
This property is of type Signed integer and can be referenced with the variable name TXB1DB7.
Data byte 7
Message ID
This property is of type Signed integer and can be referenced with the variable name TXB2ID.
CAN Message ID for Transmit Buffer 2
Length
This property is of type Signed integer and can be referenced with the variable name TXB2LEN.
D0
This property is of type Signed integer and can be referenced with the variable name TXB2DB0.
Data byte 0
D1
This property is of type Signed integer and can be referenced with the variable name TXB2DB1.
Data byte 1
D2
This property is of type Signed integer and can be referenced with the variable name TXB2DB2.
Data byte 2
D3
This property is of type Signed integer and can be referenced with the variable name TXB2DB3.
Data byte 3
D4
This property is of type Signed integer and can be referenced with the variable name TXB2DB4.
Data byte 4
D5
This property is of type Signed integer and can be referenced with the variable name TXB2DB5.
Data byte 5
D6
This property is of type Signed integer and can be referenced with the variable name TXB2DB6.
Data byte 6
D7
This property is of type Signed integer and can be referenced with the variable name TXB2DB7.
Data byte 7
Settings
This property is of type Fixed list of ints and can be referenced with the variable name RXB0CFG.
Filter setting for Receive Buffer 0
Mask
This property is of type Signed integer and can be referenced with the variable name RXM0.
Value for Receive Mask 0
Filter 0
This property is of type Signed integer and can be referenced with the variable name RXF0.
Value for Filter 0
Filter 1
This property is of type Signed integer and can be referenced with the variable name RXF1.
Value for Filter 1
Settings
This property is of type Fixed list of ints and can be referenced with the variable name RXB1CFG.
Filter setting for Receive Buffer 1
Mask
This property is of type Signed integer and can be referenced with the variable name RXM1.
Value for Receive Mask 1
Filter 2
This property is of type Signed integer and can be referenced with the variable name RXF2.
Value for Filter 2
Filter 3
This property is of type Signed integer and can be referenced with the variable name RXF3.
Value for Filter 3
Filter 4
This property is of type Signed integer and can be referenced with the variable name RXF4.
Value for Filter 4
Filter 5
This property is of type Signed integer and can be referenced with the variable name RXF5.
Value for Filter 5
