Component: I2C (Peripheral CAL)
Revision as of 15:45, 20 July 2016 by BenR (talk | contribs) (XML import)
Version 1.3 (Release)
Category Peripheral CAL
Image I2C component
Chip Abstraction Layer for Two Wire I2C Communications
Slave_Uninit
Uninitialise the Slave
This macro has no parameters
Master_Stop
Output a Master Stop
Slave_Init
Initialise the Slave with the given Address, or range of Addresses.
Only address bits that have a corresponding bit set in the Mask will be compared with the incoming bus address.
BYTE Address
7 Bit Address of this device (Bit 0 is ignored)
BYTE Mask
Bit mask used to compare addresses
Master_Uninit
Uninitialise the Master
Slave_Status
Returns the Slave Status.
Bit 0 = 1 Indicates address/data byte available in the buffer to read
Bit 5 = 1 Indicates that the last byte received or transmitted was data (else address)
BYTE
Slave_TxByte
Send a data byte, returns Ack/Nak from Master
0=Ack=More, 1=Nak=Last
BYTE Data
BYTE
Slave_RxByte
Returns the data received, and sends either Ack or Nak
Set parameter Last as: 1=Last=Nak, 0=Ack=More
BYTE Last
Sends Ack if 0, else Nak
BYTE
Master_Init
Initialise the Master
Master_Start
Output a Master Start sequence
Master_TxByte
Send a data byte
BYTE Data
BYTE
Master_Restart
Output a Master Restart sequence
Master_RxByte
Returns a received data byte
BYTE Last
BYTE
Simulation macro reference
GetValue
Get the Named property value.
STRING Name
STRING
GetConsoleHandle
Obtains the CAL console handle
HANDLE
SetValue
Change Named property to new Value.
If "CHANNEL" the ports will be also updated from the fcd
STRING Name
STRING Value
port value as string
GetList
returns Named property List as filter string
STRING Name
STRING
This property is of type Fixed list of ints and can be referenced with the variable name CHANNEL.
Channel selection
SDA
This property is of type Single digital pin and can be referenced with the variable name SDA.
SCL
This property is of type Single digital pin and can be referenced with the variable name SCL.
Baud Select
This property is of type Fixed list of ints and can be referenced with the variable name BAUD_LIST.
This property is of type Signed integer and can be referenced with the variable name BAUD.
Baud rate to be used
Slew Rate Control
This property is of type Fixed list of ints and can be referenced with the variable name SRC.
Slew Rate Control Enabled or Disabled
SMBus Inputs
This property is of type Fixed list of ints and can be referenced with the variable name SMB.
When Enabled input logic thresholds are compliant with SMBus specification
Stop Delay
This property is of type True or false and can be referenced with the variable name StopDel.
On older microcontroller devices there is a potential for the I2C hardware channel to lock up if there is not
a 10ms delay between an I2C stop event and the next I2C start event.
Most modern microcontrollers will not have a problem so this property can be disabled to speed up the
I2C communications.
This property is of type True or false and can be referenced with the variable name ScopeTraces.
This property is of type True or false and can be referenced with the variable name ConsoleData.
