Component: UART (Peripheral CAL)
Author | Matrix Ltd |
Version | 1.1 (Release) |
Category | Peripheral CAL |
UART component
A low level implementation giving direct access to the CAL
UpdateBaud
Change the Baud Rate to new_baud
- BYTE new_baud
- The new baud rate (0=1200, 7=115200)
Receive
Receive a Character
- BYTE Timeout
- Period to wait for the character to be received
Send
Send the Character
- UINT Char
- The Character to send
Init
Initialize the component with the specified properties
Delay
Software UART Bit Delay
Uninit
Un-initialize the UART and release the resources
Simulation macro reference
GetValue
Get Value of Named property
- STRING Name
GetConsoleHandle
SetValue
set Value of Named property
- STRING Name
- STRING Value
GetList
Gets Named property List
- STRING Name
This property is of type Fixed list of ints and can be referenced with the variable name CHANNEL.
UART Channel selector
TX
This property is of type Single digital pin and can be referenced with the variable name TX.
RX
This property is of type Single digital pin and can be referenced with the variable name RX.
Baud Options
This property is of type Fixed list of ints and can be referenced with the variable name BAUD_LIST.
This property is of type Signed integer and can be referenced with the variable name BAUD.
Data Bits
This property is of type Fixed list of ints and can be referenced with the variable name DBITS.
Number of data bits
This property is of type Fixed list of ints and can be referenced with the variable name RETURN.
Return data width from Receive macro
Echo
This property is of type Fixed list of ints and can be referenced with the variable name ECHO.
Echo selection
Interrupt
This property is of type Fixed list of ints and can be referenced with the variable name INT.
Interrupt mode enable or disable
Flow Control
This property is of type Fixed list of ints and can be referenced with the variable name FLOWEN.
Flow Control (Handshake) enable or disable
RTS
This property is of type Single digital pin and can be referenced with the variable name RTS.
Pin to be used for Request To Send handshake function
CTS
This property is of type Single digital pin and can be referenced with the variable name CTS.
Pin to be used for Clear To Send handshake function
This property is of type True or false and can be referenced with the variable name ScopeTraces.
This property is of type True or false and can be referenced with the variable name ConsoleData.
