Component: Touch Pads (Sensors: EBM Modules)
Author | Matrix TSL |
Version | 1.0 (Release) |
Category | Sensors: EBM Modules |
Touch Pads component
This board provides two touch areas for use with capacitive sensing. Hence two digital touch switches can be implemented. This component directly interfaces with the EBM013 Sensors board.
Sample program using the EBM013 - Touch Pads sensor.
Sensors are first calibrated and then can be read as digital switches
GetTouchValue
Samples the touch sensor ADC value and returns it
Always samples both channels, but only returns the chosen channel
- BOOL Switch
- Select Switch. Switch 1 = 0, Switch 2 = 1
GetTouchPressed
Returns non-zero if touch detected
- BOOL Switch
- Switch 1 = 0, Switch 2 = 1
- UINT OffValue
- BYTE Threshold
- Provide the threshold value for the pad to be considered touched
- BOOL : Returns true if the operation is a success, else false
Simulation macro reference
Channel 1
This property is of type Single analog pin and can be referenced with the variable name CHANNEL1.
ADC Channel number
Channel 2
This property is of type Single analog pin and can be referenced with the variable name CHANNEL2.
On Value
This property is of type Unsigned integer and can be referenced with the variable name OnVal1.
Off Value
This property is of type Unsigned integer and can be referenced with the variable name OffVal1.
On Value
This property is of type Unsigned integer and can be referenced with the variable name OnVal2.
Off Value
This property is of type Unsigned integer and can be referenced with the variable name OffVal2.
