Component: RF 2.4GHz (Wireless)
Revision as of 10:47, 3 August 2016 by BenR (talk | contribs)
Author Matrix Ltd.
Version 1.1 (Release)
Category Wireless
Image RF 2.4GHz component
A simple RF communications module based on the 2.4GHz nRF24L01 modules.
Transmit - Reads a EB014 keypad, when a key is pressed and released the chosen key is transmitted as an ASCII value to the receiver.
FC6 Icon.png Transmit Example
Receive - Sets up the receiver ready to receive messages, when a message is received the byte value is printed to the LCD.
FC6 Icon.png Receive Example
ReadRxByte
Reads a single byte back from the local Rx buffer.
BYTE Index
Byte to read, range 0 - 31
BYTE
WriteTxByte
Reads a single byte to the local Tx buffer.
BYTE Index
BYTE Value
FlushRx
Tells the RF module to flush the contents of the receive buffer.
Returns the status from sending the command.
This macro has no parameters
BYTE
ReadRxFifo
Reads the Rx FIFO buffer into a local buffer.
Use the ReadBuffer macro to collect the individual data bytes.
BYTE NumBytes
Number of bytes to try and read from the FIFO Range 1-32
WriteTxFifo
Writes the contents of the local Tx buffer to the Transmit FIFO.
BYTE NumBytes
Number of bytes to write to the FIFO, Range 1 - 32
FlushTx
Tells the RF module to flush the contents of the transmit buffer.
BYTE
CheckRX
Check the Rx FIFO status register for any new data.
Returns 0 = No data
Returns 1 = New data available
BYTE
ReadRegister
Reads a single bytes from the selected register.
Directly returns the value read back from the register.
BYTE Reg
Register address to access
BYTE
SetTxMode
Sets the module up ready to transmit data.
BYTE PA0
Pipe Address Bytes
BYTE PA1
Pipe Address Bytes
BYTE PA2
Pipe Address Bytes
BYTE PA3
Pipe Address Bytes
BYTE PA4
Pipe Address Bytes
SetRxMode
Sets the module up ready to receive data.
BYTE PA0
Pipe Address Bytes
BYTE PA1
Pipe Address Bytes
BYTE PA2
Pipe Address Bytes
BYTE PA3
Pipe Address Bytes
BYTE PA4
Pipe Address Bytes
WriteRegister
Writes a single byte to the selected register.
Returns the status of the write command.
BYTE Reg
BYTE Value
BYTE
Starts up and configures the RF module ready for use.
The macro will return a value greater then 0 if the module has been started correctly, otherwise the macro will return a 0.
UINT
Simulation macro reference
RF Channel
This property is of type Unsigned integer and can be referenced with the variable name RFChannel.
Sets the RF channel from 0 - 127 = 2.4000GHz - 2.525GHz
Both the transmitter and receiver should be on the same channel to receive data.
SPI Channel
This property is of type Fixed list of ints and can be referenced with the variable name Channel.
SPI peripheral used to talk to the RF module.
MOSI Pin
This property is of type Single digital pin and can be referenced with the variable name mosi_pin.
SPI Data Out pin - Master Out Slave In
MISO Pin
This property is of type Single digital pin and can be referenced with the variable name miso_pin.
SPI Data In pin - Master In Slave Out
SCK Pin
This property is of type Single digital pin and can be referenced with the variable name sck_pin.
Serial clock pin
CE Pin
This property is of type Single digital pin and can be referenced with the variable name ce_pin.
Chip enable, configures RX or TX mode
CSN Pin
This property is of type Single digital pin and can be referenced with the variable name csn_pin.
SPI chip select pin - enables the SPI interface when pulled low
