Component: Combo Board (EB083) (Displays: Alphanumeric)
Revision as of 15:13, 18 August 2016 by BenR (talk | contribs)
Version 1.0 (Release)
Category Displays: Alphanumeric
This inherits from LCD (Generic)
Image Combo Board (EB083) component
A simulated version of the EB083 Combo board including LEDs, Switches, LCD, 7-Segs and analogue inputs.
Example to read the value of the light sensor and potentiometer and display the readings on the LCD.
Both the "PortA Mode Select" jumpers need to be in the ANA position and the LCD switch needs to be in the On position.
FC6 Icon.png EB083_Example1
Example to output a numeric value to the quad seven segment display. The counter is incremented by pressing the switch connected to pin A4.
Both the "PortA Mode Select" jumpers need to be in the DIG position and the 7-Seg switch needs to be in the On position.
FC6 Icon.png EB083_Example2
This component inherits downloadable macros from LCD (Generic)
Clear
This call is provided by LCD (Generic)
This macro has no parameters
PrintString
<- STRING Text
Enter the text or variable to print to the LCD
This parameter may be returned back to the caller
PrintAscii
BYTE character
Holds an ascii value.
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
INT Number
RAMWrite
BYTE Index
Values 0 to 7
BYTE d0
BYTE d1
BYTE d2
BYTE d3
BYTE d4
BYTE d5
BYTE d6
BYTE d7
ClearLine
BYTE Line
The line to clear, zero being the first (top) line of the display
Cursor
BYTE x
Set the cursor position in the X plane, 0 is the left most cell
BYTE y
Set the cursor position in the Y plane, 0 is the top most cell
Command
BYTE instruction
Send a defined command to the LCD Screen. See datasheet for supported commands.
PrintFormattedNumber
Will allow you to print a number up to 32-bits with signed or unsigned formatting.
Signed = -2147483648 to 2147483647
Unsigned = 0 to 4294967295
ULONG Number
BOOL Format
0=Signed, 1=Unsigned
ScrollDisplay
BYTE Position
Holds the number of positions to shift the display
BYTE direction
0 = left, 1 = right
RawSend
Sends data to the LCD display
BYTE data
The data byte to send to the LCD
BOOL type
A boolean to indicate command type: true to write data, false to write a command
Start
Startup routine required by the hardware device.
Automatically clears the display after initialising.
SetPort
Sets the state of a single port
BYTE Port
0 = PortA, 1 = PortB
BYTE Value
GetSwitchState
Reads the state of a single switch
BYTE Port
BYTE Switch
0 = SW0, 7 = SW7
BYTE
GetPort
Reads the state of a single port
BYTE Port
BYTE
SegShowDigit
Displays a digit on the 7-seg display
BYTE Digit
Which of the digits to change (0 - 3)
BYTE Value
The value to display (0 - 9)
BYTE DecimalPoint
Decides if the decimal point is lit
ReadAnalogAsByte
Reads one of the analogue components as an byte value
BYTE Channel
0 = LDR, 1 = POT
BYTE
ReadAnalogAsInt
Reads one of the analogue components as an Integer value
BYTE Channel
0 = LDR, 1 = POT
INT
SetLEDState
Sets the state of a single LED
BYTE Port
BYTE LED
0 = LED0, 7 = LED7
BYTE State
Simulation macro reference
Pin A0
This property is of type Single digital pin and can be referenced with the variable name PinA0.
Pin A1
This property is of type Single digital pin and can be referenced with the variable name PinA1.
Pin A2
This property is of type Single digital pin and can be referenced with the variable name PinA2.
Pin A3
This property is of type Single digital pin and can be referenced with the variable name PinA3.
Pin A4
This property is of type Single digital pin and can be referenced with the variable name PinA4.
Pin A5
This property is of type Single digital pin and can be referenced with the variable name PinA5.
Pin A6
This property is of type Single digital pin and can be referenced with the variable name PinA6.
Pin A7
This property is of type Single digital pin and can be referenced with the variable name PinA7.
Pin B0
This property is of type Single digital pin and can be referenced with the variable name PinB0.
Pin B1
This property is of type Single digital pin and can be referenced with the variable name PinB1.
Pin B2
This property is of type Single digital pin and can be referenced with the variable name PinB2.
Pin B3
This property is of type Single digital pin and can be referenced with the variable name PinB3.
Pin B4
This property is of type Single digital pin and can be referenced with the variable name PinB4.
Pin B5
This property is of type Single digital pin and can be referenced with the variable name PinB5.
Pin B6
This property is of type Single digital pin and can be referenced with the variable name PinB6.
Pin B7
This property is of type Single digital pin and can be referenced with the variable name PinB7.
