Component: Combo Board (EB083) (Displays: Alphanumeric)
Author | Matrix TSL |
Version | 1.0 (Release) |
Category | Displays: Alphanumeric |
This inherits from LCD (Generic) |
Combo Board (EB083) component
A simulated version of the EB083 Combo board including LEDs, Switches, LCD, 7-Segs and analogue inputs.
Example to read the value of the light sensor and potentiometer and display the readings on the LCD.
Both the "PortA Mode Select" jumpers need to be in the ANA position and the LCD switch needs to be in the On position. The 7-Seg switch should be in the Off position.
Example to output a numeric value to the quad seven segment display. The counter is incremented by pressing the switch connected to pin A4.
Both the "PortA Mode Select" jumpers need to be in the DIG position and the 7-Seg switch needs to be in the On position. The LCD switch should be in the Off position.
The seven segment refresh rate is governed by the settings of the timer interrupt enable icon.
This component inherits downloadable macros from LCD (Generic)
Clear
This call is provided by LCD (Generic)
PrintString
- <- STRING Text
- Enter the text or variable to print to the LCD
PrintAscii
- BYTE character
- Holds an ascii value.
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
- INT Number
- Enter the number or variable to print to the LCD
RAMWrite
- BYTE Index
- Values 0 to 7
- BYTE d0
- BYTE d1
- BYTE d2
- BYTE d3
- BYTE d4
- BYTE d5
- BYTE d6
- BYTE d7
ClearLine
- BYTE Line
- The line to clear, zero being the first (top) line of the display
Cursor
- BYTE x
- Set the cursor position in the X plane, 0 is the left most cell
- BYTE y
- Set the cursor position in the Y plane, 0 is the top most cell
Command
- BYTE instruction
- Send a defined command to the LCD Screen. See datasheet for supported commands.
PrintFormattedNumber
Will allow you to print a number up to 32-bits with signed or unsigned formatting.
Signed = -2147483648 to 2147483647
Unsigned = 0 to 4294967295
- ULONG Number
- BOOL Format
- 0=Signed, 1=Unsigned
ScrollDisplay
- BYTE Position
- Holds the number of positions to shift the display
- BYTE direction
- 0 = left, 1 = right
RawSend
Sends data to the LCD display
- BYTE data
- The data byte to send to the LCD
- BOOL type
- A boolean to indicate command type: true to write data, false to write a command
Start
Startup routine required by the hardware device.
Automatically clears the display after initialising.
SetPort
Sets the state of a single port
- BYTE Port
- 0 = PortA, 1 = PortB
- BYTE Value
GetSwitchState
Reads the state of a single switch
- BYTE Port
- BYTE Switch
- 0 = SW0, 7 = SW7
GetPort
Reads the state of a single port
- BYTE Port
SegShowDigit
Displays a digit on the 7-seg display
- BYTE Digit
- Which of the digits to change (0 - 3)
- BYTE Value
- The value to display (0 - 9)
- BYTE DecimalPoint
- Decides if the decimal point is lit
ReadAnalogAsByte
Reads one of the analogue components as an byte value
- BYTE Channel
- 0 = LDR, 1 = POT
ReadAnalogAsInt
Reads one of the analogue components as an Integer value
- BYTE Channel
- 0 = LDR, 1 = POT
SetLEDState
Sets the state of a single LED
- BYTE Port
- BYTE LED
- 0 = LED0, 7 = LED7
- BYTE State
Simulation macro reference
Pin A0
This property is of type Single digital pin and can be referenced with the variable name PinA0.
Pin A1
This property is of type Single digital pin and can be referenced with the variable name PinA1.
Pin A2
This property is of type Single digital pin and can be referenced with the variable name PinA2.
Pin A3
This property is of type Single digital pin and can be referenced with the variable name PinA3.
Pin A4
This property is of type Single digital pin and can be referenced with the variable name PinA4.
Pin A5
This property is of type Single digital pin and can be referenced with the variable name PinA5.
Pin A6
This property is of type Single digital pin and can be referenced with the variable name PinA6.
Pin A7
This property is of type Single digital pin and can be referenced with the variable name PinA7.
Pin B0
This property is of type Single digital pin and can be referenced with the variable name PinB0.
Pin B1
This property is of type Single digital pin and can be referenced with the variable name PinB1.
Pin B2
This property is of type Single digital pin and can be referenced with the variable name PinB2.
Pin B3
This property is of type Single digital pin and can be referenced with the variable name PinB3.
Pin B4
This property is of type Single digital pin and can be referenced with the variable name PinB4.
Pin B5
This property is of type Single digital pin and can be referenced with the variable name PinB5.
Pin B6
This property is of type Single digital pin and can be referenced with the variable name PinB6.
Pin B7
This property is of type Single digital pin and can be referenced with the variable name PinB7.
