Component: LED WS2801 (Outputs: LEDs)
Revision as of 09:11, 25 August 2016 by BenR (talk | contribs)
Version 1.0 (Release)
Category Outputs: LEDs
Image LED WS2801 component
A simple chained RGB LED controller IC allowing multiple LEDs to be controlled using a serial data stream. Allows RGB LEDs to be driven with full 24-bit colour depth. Allows single chains, 2D arrays and 3D cube formations to be simulated. Supports Bit Banged or SPI peripheral based data modes.
RGB Mood Light
A simple example using three potentiometers to set the individual Red, Green and Blue channels of the LED colour.
FC6 Icon.png MoodLight
Animated Light
A simple example which picks a random colour assigns it to the first LED, then shifts and repeats.
FC6 Icon.png AnimLightStrip
DrawLine2D
Draws a line on a 2D array of LEDs
UINT X1
UINT Y1
UINT X2
UINT Y2
BYTE R
BYTE G
BYTE B
SetAllLEDColour
Sets the colour of all the LEDs in RAM
BYTE R
BYTE G
BYTE B
SetLEDColour
Sets the colour of a single LED in RAM as a 1D array.
UINT LED
LED to change the colour / Range: 0 to (LED Count - 1)
BYTE R
BYTE G
BYTE B
Refresh
Clocks out the current colour data to the LEDs from the values stored in RAM
This macro has no parameters
DrawLine3D
Draws a line on a 3D array of LEDs
UINT X1
UINT Y1
UINT Z1
UINT X2
UINT Y2
UINT Z2
BYTE R
BYTE G
BYTE B
SetLEDColour2D
Sets the colour of a single LED in RAM as a 2D array.
UINT LED_Column
LED Column to change the colour / Range: 0 to (LED Column - 1)
UINT LED_Row
LED Row to change the colour / Range: 0 to (LED Row - 1)
BYTE R
BYTE G
BYTE B
SetLEDColour3D
Sets the colour of a single LED in RAM as a 3D array.
UINT LED_Column
UINT LED_Row
UINT LED_Layer
LED Layer to change the colour / Range: 0 to (LED Layer - 1)
BYTE R
BYTE G
BYTE B
Inisialises the RGB colour RAM to 0,0,0 = LED Off and clocks out the data to
initialise all the WS2801 ICs in the chain.
Simulation macro reference
LED Arrangement
This property is of type Fixed list of ints and can be referenced with the variable name LED_Arrangement.
Controls the arrangement of the LEDs on the panel.
1D - Creates a straight line of LEDs
2D - Creates an X by Y Array of LEDs
3D - Creates an X by Y by Z Array of LEDs
LED Count
This property is of type Unsigned integer and can be referenced with the variable name LED_Count.
Total number of LEDs in the design
LED Columns
This property is of type Unsigned integer and can be referenced with the variable name LED_Cols.
Number of horizontal LEDs - X axis
LED Rows
This property is of type Unsigned integer and can be referenced with the variable name LED_Rows.
Number of vertical LEDs - Y axis
LED Layers
This property is of type Unsigned integer and can be referenced with the variable name LED_Layers.
Number of LED layers - Z axis
Output Mode
This property is of type Fixed list of ints and can be referenced with the variable name Output_Mode.
Sets the output mode used to drive the data to the LEDs
Bit Banged Mode = Allows Any I/O Pin but may be slower
SPI Mode = Fixed SPI Peripheral Pins but may be faster - Note that the SPI MISO pin will not be available for general I/O
Data Pin
This property is of type Single digital pin and can be referenced with the variable name MOSI.
LED Data Pin - Connected to the Data In pin of the first WS8201 IC.
Clock Pin
This property is of type Single digital pin and can be referenced with the variable name CLK.
LED Clock Pin - Connected to the Clock In pin of the first WS8201 IC.
