Component: LED WS2811 WS2812 (Outputs: LEDs)
Revision as of 11:46, 25 August 2016 by BenR (talk | contribs) (Created page with "{| width="50%" |- | width="20%" style="color: gray;" | Author | Matrix TSL |- | width="20%" style="color: gray;" | Version | 1.0 (Release) |- | width="20%" style="color: gray;...")
Version 1.0 (Release)
Category Outputs: LEDs
Image LED WS2811 WS2812 component
A simple chained RGB LED controller IC allowing multiple LEDs to be controlled using a serial data stream. Compatible with the WS2811, WS2812 and WS2812B Type Controller ICs. Allows RGB LEDs to be driven with full 24-bit colour depth. Allows single chains, 2D arrays and 3D cube formations to be simulated. Requires a high speed microcontroller to generate the critical timings to drive the device.
GetLEDColour
Sets the colour of a single LED in RAM as a 1D array.
UINT LED
LED to change the colour / Range: 0 to (LED Count - 1)
BYTE ColIdx
0 = R, 1 = G, 2 = B
BYTE
DrawLine2D
Draws a line on a 2D array of LEDs
UINT X1
UINT Y1
UINT X2
UINT Y2
BYTE R
BYTE G
BYTE B
SetAllLEDColour
Sets the colour of all the LEDs in RAM
BYTE R
BYTE G
BYTE B
SetLEDColour
UINT LED
BYTE R
BYTE G
BYTE B
Refresh
Clocks out the current colour data to the LEDs from the values stored in RAM
This macro has no parameters
ShiftLEDs1D
Shifts the LED colours in 1D and wraps
BYTE Direction
0 = Forwards, 1 = Backwards
DrawLine3D
Draws a line on a 3D array of LEDs
UINT X1
UINT Y1
UINT Z1
UINT X2
UINT Y2
UINT Z2
BYTE R
BYTE G
BYTE B
GetLEDIndex2D
Sets the index of a single LED in RAM as a 2D array.
UINT LED_Column
LED Column to change the colour / Range: 0 to (LED Column - 1)
UINT LED_Row
LED Row to change the colour / Range: 0 to (LED Row - 1)
UINT
GetLEDIndex3D
Gets the index of a single LED in RAM as a 3D array.
UINT LED_Column
UINT LED_Row
UINT LED_Layer
LED Layer to change the colour / Range: 0 to (LED Layer - 1)
UINT
Inisialises the RGB colour RAM to 0,0,0 = LED Off and clocks out the data to
initialise all the WS2801 ICs in the chain.
Simulation macro reference
LED Controller
This property is of type Fixed list of ints and can be referenced with the variable name LED_Controller.
Reset Time (uS)
This property is of type Floating point and can be referenced with the variable name Reset_Time.
T0H (uS)
This property is of type Floating point and can be referenced with the variable name T0H.
T0L (uS)
This property is of type Floating point and can be referenced with the variable name T0L.
T1H (uS)
This property is of type Floating point and can be referenced with the variable name T1H.
T1L (uS)
This property is of type Floating point and can be referenced with the variable name T1L.
LED Arrangement
This property is of type Fixed list of ints and can be referenced with the variable name LED_Arrangement.
Controls the arrangement of the LEDs on the panel.
1D - Creates a straight line of LEDs
2D - Creates an X by Y Array of LEDs
3D - Creates an X by Y by Z Array of LEDs
LED Count
This property is of type Unsigned integer and can be referenced with the variable name LED_Count.
Total number of LEDs in the design
LED Columns
This property is of type Unsigned integer and can be referenced with the variable name LED_Cols.
Number of horizontal LEDs - X axis
Column Spacing
This property is of type Floating point and can be referenced with the variable name x_spacing.
LED Rows
This property is of type Unsigned integer and can be referenced with the variable name LED_Rows.
Number of vertical LEDs - Y axis
Row Spacing
This property is of type Floating point and can be referenced with the variable name y_spacing.
LED Layers
This property is of type Unsigned integer and can be referenced with the variable name LED_Layers.
Number of LED layers - Z axis
Layer Spacing
This property is of type Floating point and can be referenced with the variable name z_spacing.
Data Pin
This property is of type Single digital pin and can be referenced with the variable name MOSI.
LED Data Pin - Connected to the Data In pin of the first WS8201 IC.
