Component: LCD (Grove UART) (Displays: Alphanumeric)
Revision as of 15:46, 16 February 2017 by BenR (talk | contribs) (XML import BR)
Version 1.4 (Release)
Category Displays: Alphanumeric
This inherits from LCD (Generic)
Image LCD (Grove _ UART) component
Standard alphanumeric LCD based on the Grove display module.
This component inherits downloadable macros from LCD (Generic)
Clear
This macro has no parameters
PrintString
<- STRING Text
This parameter may be returned back to the caller
PrintAscii
BYTE character
Allows you to print a number. This is limited to a signed-INT, -32768 to 32767
INT Number
RAMWrite
This call is provided by LCD (Generic)
BYTE Index
Values 0 to 7
BYTE d0
BYTE d1
BYTE d2
BYTE d3
BYTE d4
BYTE d5
BYTE d6
BYTE d7
ClearLine
BYTE Line
Cursor
BYTE x
BYTE y
Command
BYTE instruction
Send a defined command to the LCD Screen. See datasheet for supported commands.
PrintFormattedNumber
Will allow you to print a number up to 32-bits with signed or unsigned formatting.
Signed = -2147483648 to 2147483647
Unsigned = 0 to 4294967295
ULONG Number
BOOL Format
0=Signed, 1=Unsigned
ScrollDisplay
BYTE position
Number of positions to scroll the display
BYTE direction
Direction to scroll the display: 0=Left, 1=Right
RawSend
Sends data to the LCD display
BYTE data
The data byte to send to the LCD
BOOL type
A boolean to indicate command type: true to write data, false to write a command
RemapCharacter
Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters.
The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
BYTE RemapIdx
Remap Index, Range: 0 to (Remap Characters - 1)
BYTE SearchCharacter
Character to look for a replace
BYTE ReplacementCharacter
New character value to use in place of the search character.
Start
Startup routine required by the hardware device.
BacklightControl
BYTE State
0=Backlight Off, 1=Backlight On
Simulation macro reference
This property is of type Fixed list of ints and can be referenced with the variable name Channel.
TX Pin
This property is of type Single digital pin and can be referenced with the variable name tx_pin.
UART transmit pin - connected to the RX pin on the Grove display
RX Pin
This property is of type Single digital pin and can be referenced with the variable name rx_pin.
UART receive pin - connected to the TX pin on the Grove display
Rows
This property is of type Fixed list of ints and can be referenced with the variable name Rows.
Columns
This property is of type Fixed list of ints and can be referenced with the variable name Columns.
