Component: Matrix Robot Arm (Electro Mechanical Simulation)
Revision as of 15:46, 16 February 2017 by BenR (talk | contribs) (XML import BR)
Version 0.2 (Development)
Category Electro Mechanical Simulation
Image Matrix Robot Arm component
Matrix 5-axis Robot Arm with Gripper. Compatible with the Matrix Robot ARM Training Curriculum and Hardware. Features gripper pressure sensor, light sensor, colour sensor, Potentiometer, Magnetic sensor.
This component does not contain any downloadable macros
Simulation macro reference
LEDOn
Switches on a single LED, LA0-LA7
BYTE Index
0=LA0, 1=LA1, 2=LA2, 3=LA3, 4=LA4, 5=LA5, 6=LA6, 7=LA7
ReadLight
Read the value of the light sensor on the EB090 board.
Returns the value as a byte
This macro has no parameters
BYTE
StoreCoords
Stores the provided coordinates as a position the ARM can recall.
BYTE Index
Save Index - Range 0-29
BYTE Position0
Range: 0-180
BYTE Position1
Range: 0-180
BYTE Position2
Range: 0-180
BYTE Position3
Range: 0-180
BYTE Position4
Range: 0-180
LCDClearLine
BYTE Line
The line to clear, zero being the first (top) line of the display
LEDOff
Switches off a single LED, LA0-LA7
BYTE Index
LEDWrite
Allows a value to be sent to control all eight LEDs LA0-LA7 at once
BYTE Value
(0-63) 0b000000
GetAPIVersion
Gets the API version of the Robot ARM Firmware
BYTE
GripperOpen
Fully opens the gripper at the end of the arm ready to pick something up.
KineSetXYZ
Sets the XYZ position and calculates the various servo motor angles required.
Returns 0=Impossible, 1=InPosition
INT X
INT Y
INT Z
BYTE
ReadSwitch
Read the value of a single switch.
BYTE index
0=SA0, 1=SA1, 2=SA2, 3=SA3, 4=SA4, 5=SA5, 6=SA6, 7=SA7
BYTE
LCDPrintStr
<- STRING PrintString
Enter the text or variable to print to the LCD
This parameter may be returned back to the caller
SetAllServos
Move all the servo positions between 0-180 Deg
BYTE Servo0_Base
Position of servo0 in degrees (0-180)
BYTE Servo1_Shoulder
Position of servo1 in degrees (0-180)
BYTE Servo2_Elbow
Position of servo2 in degrees (0-180)
BYTE Servo3_Wrist
Position of servo3 in degrees (0-180)
BYTE Servo4_WristRotate
Position of servo4 in degrees (0-180)
ReadColourChannel
Reads a single colour channel from the value returned from the ReadColour macro.
BYTE Index
0=Red, 1=Green, 2=Blue
UINT Colour
BYTE
Park
Parks the Robot ARM and switches off the servo motors
StorePosition
Stores the current position of the ARMs 5 axis.
BYTE Index
ReadPressure
Read the value of the pressure sensor on the ARM gripper.
BYTE
GotoPosition
Recalls a previously saved position for the ARMs 5 axis.
BYTE Index
MotorsMoving
Checks to see if any of the motors are still moving.
BYTE
Beep
Allows the beeper to output a warning
BYTE Iterations
Number of times to repeat
UINT OnDelay
Delay in ms
UINT OffDelay
Delay in ms
BYTE
ReadPot
Read the value of the potentiometer on the EB090 board.
BYTE
SetTrim
Allows minor adjustment on the 5 axis servo motors
BYTE Index
Motor Index Range 0-4
BYTE Trim
Amount of Trim Range 0-255, Default Value 128
SetServo
Move the specified servo motor position between 0-180 Deg
BYTE Index
Range 0-4 : 0=Base, 1=Shoulder, 2=Elbow, 3=Wrist, 4=WristRotate
BYTE Position
Position of servo in degrees (0-180)
GripperClose
Fully closes the gripper at the end of the arm ready to pick something up.
Closes to a defined pressure using the built in pressure sensor.
Returns 0 if nothing detected in the gripper
Returns 1 if a valid object is detected
BYTE Pressure
Range 1 - 100, Default Pressure = 20
BYTE
KineGetXYZ
Calculates the current XYZ position from the current servo position coordinates
BYTE Index
Range 0-2 : 0=X, 1=Y, 2=Z
INT
ReadColour
Samples the Colour Sensor and reads the levels of Red, Green and Blue Light back as a 16-bit UINT variable.
The colour format is 0b0BBBBBGGGGGRRRRR.
The ReadColourChannel macro can be used to get individual channel colours.
UINT
LCDVerbose
Controls if the LCD is in user mode or verbose API mode,
BYTE Mode
0=User Mode, 1=API Verbose Mode
LCDCursor
BYTE X
Set the cursor position in the X plane, 0 is the left most cell (0-15)
BYTE Y
Set the cursor position in the Y plane, 0 is the top most cell (0-1)
LCDPrintNum
Will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
INT Number
LCDClear
Mode
This property is of type Fixed list of ints and can be referenced with the variable name SimMode.
API Connection Type
This property is of type Fixed list of ints and can be referenced with the variable name APIType.
COM Port
This property is of type Fixed list of ints and can be referenced with the variable name COM_port.
Refresh COM Ports
This property is of type True or false and can be referenced with the variable name Refresh.
Baud
This property is of type Signed integer and can be referenced with the variable name baud_rate.
