Component: RFID (EB052, RWD MICODE) (Wireless)
Revision as of 15:46, 16 February 2017 by BenR (talk | contribs) (XML import BR)
Author Matrix Ltd.
Version 1.3 (Release)
Category Wireless
Image RFID (EB052, RWD_MICODE) component
Low level routines for controlling a RF Solutions RFID interface Allows communications between Mifare, ICode and HiTag type RFID tags. Also available in the form of the EB052 RFID E-block.
Reading the status
The status of the RFID module is read using the "GetRFIDStatus" macro which returns a byte which is then displayed using the PORTB pins. FC6 Icon.png RFID Status Status byte breakdown for Mifare.
Status byte breakdown for ICode.
Status byte breakdown for HiTag.
Status byte breakdown for EM Marin.
Reading and Writing Data
Example which talks to a ICode type card and allows the data to be read and written via a keypad. FC6 Icon.png RFID Read/Write
Macro compatibility
Not all the macros can be used with all card types, here is a list of RFID transponder types and the macros that are compatible.
GetRFIDTypeID
Collects the 3 bytes required to determine which kind of MIFARE device is present. Stores the result into the local buffer 0 - 2 and returns the response of the module.
This macro has no parameters
BYTE
WriteRFIDBlock
Writes a block of information to the RFID device.
BYTE Address
Remote RFID Block Address.
BYTE Key_Type
BYTE
WriteRFIDModule
Stores a byte of data to the internal EEPROM of the RFID module at the address specified.
BYTE Address
BYTE Data
BYTE
DecrementRFIDValue
Perfoms a 32-bit decrement on the number held in location page or block.
BYTE Src
Page / Block
BYTE Dst
Page / Block
BYTE Key_Type
Needed for MIFARE Commands
BYTE
FormatRFIDValue
Initialises the internal buffer of the Microcontroller so that it is ready to perform a Increment, Decrement or Transfer command.
IncrementRFIDValue
Perfoms a 32-bit increment on the number held in location page or block.
BYTE Src
Page / Block
BYTE Dst
Page / Block
BYTE Key_Type
BYTE
StoreRFIDKey
Stores a 6 byte key for use with MIFARE type devices that require authorisation.
BYTE Key
Key Location 0 - 31
BYTE D0
Least significant byte of key
BYTE D1
BYTE D2
BYTE D3
BYTE D4
BYTE D5
Most significant byte of key
BYTE
WriteRFIDBuffer
Writes a byte of data to the outgoing buffer.
BYTE Address
The address of the buffer 0 - 15
BYTE Data
The data to be stored in the buffer location 0 - 255.
GetRFIDStatus
Collect the status of the RFID device (see help for the explaination of the status byte).
UINT
ReadRFIDBuffer
Reads a byte of data from the incoming buffer.
BYTE Address
BYTE
TransferRFIDValue
Perfoms a 32-bit block data transfer on the number held in location page or block.
BYTE Src
Page / Block
BYTE Dst
Page / Block
BYTE Key_Type
BYTE
GetRFIDUID
Collects the UID from a RFID device. Stores the result into the UID buffer and returns the response of the module.
BYTE
ReadRFIDUID
Reads a byte of data from the UID buffer.
BYTE Address
The address of the buffer 0 - 7
BYTE
ReadRFIDBlock
Reads a block of information from the RFID device.
BYTE Address
BYTE Key_Type
BYTE
Configures the RFID device by presetting the Osc type and Mode via the Flowcode component properties.
BYTE
Simulation macro reference
CHANNEL
This property is of type Fixed list of ints and can be referenced with the variable name CHANNEL.
Card_Type
This property is of type Fixed list of ints and can be referenced with the variable name Card_Type.
CTS
This property is of type Single digital pin and can be referenced with the variable name CTS.
TX
This property is of type Single digital pin and can be referenced with the variable name TX.
RX
This property is of type Single digital pin and can be referenced with the variable name RX.
